Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th December 2009, 05:36 AM   #1
Default Best place to buy high end broken recievers.
I want to know where is a good place to buy high end recievers that are broken? reason for this is to see what kind of components they use to build it and salvage the expensive components to build one "like the transformer and heat sinks" and the exterior.
Old 11th December 2009, 08:08 AM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Probably not worth it unless you don't care what you build. The components you mention may not be off-shelf so they are developed to fit the application they are used in and may thus not fit yours. Recycling electronic components wouldn't be my first choice either.
/U.
Old 12th December 2009, 05:57 PM   #3
You have any idea how much a 1000watt transformer cost? or heatsinks to dissapate heat for a 100watt channel would cost? Each can easily cost over a 100 dollars each because we buy them in small quantities. while for a companie that buy them by the 1000s can cut thoese prices buy half some times by more. I work in a companie and we do smt production for products we build and for outside customers. Let me tell you we do recycles parts some times because of late parts that come in but we havent scrapped the boards that didnt work because most parts on it still works and have only been soldered once. And by IPC standards Class 3 "Military" you can do it 3 times maximume befor you have to throw out the part.
That is for part recycling, my other section of my question was i was curiouse to see what kind of parts "companys, chip models..." they used to make there reciever work for what is called high end.
Old 14th December 2009, 03:02 AM   #4
Glowbug is offline Glowbug  United States
Glowbug's Avatar
I'd check Audiokarma for broken vintage stuff, I'd have faith there's more metal in there than the newer ones
Or just check Craigslist or your local fleamarkets...amazing what turns up sometimes.
Jim J.
Schematics wanted for these recievers gain Solid State 2 15th December 2010 09:08 AM
Wanted: High-end headphones & IEMs, even if battered or broken Spasticteapot Swap Meet 0 21st September 2008 01:33 AM
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? jarthel Parts 12 26th July 2007 09:08 AM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 09:26 AM
Recievers? Tuners? RF? DIY?? RMS Solid State 0 27th November 2002 04:49 PM
Page generated in 0.07824 seconds (73.22% PHP - 26.78% MySQL) with 10 queries
