Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th December 2009, 07:08 PM   #1
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Does anyone have an easy to understand primer
on how to calculate the "cooling" demands for a solid state part.
For instance I'm planning on using the IX20N50D as a CCS in the tail of an output stage. Thus it should sink around 120mA. How can I calculate if I need heatsinks. And how big the heatsinks should be.
Thank you in advance.
Old 7th December 2009, 07:53 PM   #2
Steve Dunlap's Avatar
For instance I'm planning on using the IXN20N50D as a CCS in the tail of an output stage. Thus it should sink around 120mA. How can I calculate if I need heatsinks. And how big the heatsinks should be.
Do you have a spec sheet for that part? When I Goggled it, your post was the only hit.
The power dissipation will be 120ma X voltage drop across CCS.
Old 7th December 2009, 08:24 PM   #3
Here it is:
Sorry about the spelling error.
Old 7th December 2009, 08:30 PM   #4
voltage drop
I'll be able to calculate the dissipation once I measure the voltage drop. But how can you read in the datasheet what the thing can handle? With tubes it's easy. They just state maximum dissipation of the plate.
In this device's datasheet they say 400W. But that is obviously just theoretically?
Old 7th December 2009, 08:32 PM   #5
SY's Avatar
Basically, it's set up just like an Ohm's Law problem. You start with the power the device will dissipate (voltage across it times current), then use the various thermal resistances multiplied by the power to see what the temperature is likely to be. What's the voltage across the device expected to be?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 7th December 2009, 08:47 PM   #6
SY's Avatar
Aha, here's a note on how to do it.
http://www.ixysrf.com/pdf/switch_mod...issipation.pdf
Frankly, for what's likely to be 5-6W, a small bolt-on heatsink will probably work fine. If the heatsink is rater 10°/W, the 5-6 watts will raise the temperature to about 75°, which is fairly hot but no-where near danger. The junction temp will be sitting a few degrees hotter because of unction to case and case to heatsink thermal resistances. But anything under 100°C is no real issue.
Old 7th December 2009, 09:16 PM   #7
Thanks Stuart!
I don't know. Since the ccs will drop less voltage then say a resistor I think? It will be used in a PP 6N3C-e for one of my sons.
But like you said. A bolt on type should suffice. I was hoping these would suffice.
Maße: B X H X T: ca. (25mm, 25mm, 43mm)
Zum einlöten (RA 26mm)
für Gehäuse TO220
Gewicht: 0,100Kg.
They mention TO220. But the TO-249's fit too.
Old 7th December 2009, 09:24 PM   #8
That should work.
Old 7th December 2009, 09:27 PM   #9
That should work.
Thanks Steve.
Old 7th December 2009, 09:58 PM   #10
Semiconductor Safe Operating Area
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Primer For MDF loudvegas Construction Tips 8 15th September 2009 11:51 PM
primer for fiberglass pjoseph Subwoofers 5 3rd August 2009 11:03 PM
Fi Primer 807 Klimon Tubes / Valves 2 13th November 2007 06:58 AM
A cooling Primer? Pbassred Solid State 9 29th March 2007 05:00 PM
T-Amp Mods - Easy to understand and do aussiebuddha Class D 11 30th September 2006 02:45 PM
Page generated in 0.12109 seconds (80.38% PHP - 19.62% MySQL) with 11 queries
