Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd December 2009, 07:45 PM   #1
MikeHunt79's Avatar
Post Where can I buy a SST 39SF040 EEPROM in the UK?
As title really, it's the type used in the DCX 2496, mine seems to be bad, and need a replacement!
Old 2nd December 2009, 09:37 PM   #2
This chip is not an EEPROM but a Flash CMOS BIOS type. It seems to be obsolete, and I could only find one place to get it without going through military vendors and having to buy in surplus.
Lot of 2 Used BIOS Chips. Model: SST 39SF040 - eBay (item 350283369643 end time Dec-23-09 06:30:23 PST)
Bios Chip SST 39SF040 Laptop HP Compaq Presari Pavilion - eBay (item 170409802629 end time Dec-20-09 19:19:30 PST)
Both are US/Can vendors. I could not find one in the UK.
Old 2nd December 2009, 11:20 PM   #3
MikeHunt79's Avatar
Thanks, I forgot to say, they need to be PLCC32/DIP32 packaged also, tho I guess I could use an adaptor.
Would I be able to use another part in it's place? It holds the firmware in a DEQ2496...
Old 3rd December 2009, 12:02 AM   #4
Memory - Flash - 29F040
Its somewhat comparable and sells to the UK. Check the pin-out sheet, sells in PLCC form.
Old 3rd December 2009, 11:08 PM   #5
MikeHunt79's Avatar
Thanks, I'll check out the 29F040 datasheet, I think if the pinout matches then it should work.
how would read software put on ssts7sf010 eeprom?? prorms Everything Else 0 2nd November 2007 12:54 AM
93C66B EEPROM and forgetful memory rtarbell Everything Else 1 2nd November 2007 12:17 AM
Unsoldering EEPROM chips rtarbell Parts 1 21st February 2006 11:45 PM
Page generated in 0.07175 seconds (70.89% PHP - 29.11% MySQL) with 10 queries
