| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I've recently opened some old Rotel speakers with the intention of replacing the crossover capacitors. Speakers are 2-way with 8" woofers and date from the 1970s. That's all I know. I have located the capacitor on the crossover, and belive it is a non-polarised electrolytic type. There is no code I recognise on the capacitor, only the folowing: ZEID 5 / 24 Rver. (Sorry, no picture). It is metalic blue and the size of a cigarete butt (technical!). Can anyone help me determine the value of this capacitor? Thank you, RM |
#2 |
It is probably 5uF 24v , I know it is a wierd value but they used a lot of wierd values back in the day ... If you have a capacitance setting on your DMM you can test it to make sure .....
Cheers |
#3 |
Thank you for your help.
You mention it is a weird value, but does it 'sound' like a correct value? I'm afriad I know nothing of these parts..... Aslo, I notice people mention caps with higher ratings, 100V and up. Is it a good idea to replace like-for-like (24V) or to go for a higher rating? Many thanks again, Russ |
#4 | |
no problem replace with same 24v or going with higher voltage rating,as long as the capacitance value is the same,if the old is 5uf,replace them with 5uf too |
#5 |
Thanks a lot. I'll give it a go and hope it helps!
Russ |
#6 |
5uF is rare now. But 4.7uF is ubiquitous. It's a close enough match. Electrolytic caps - which that one is likely to be, given the voltage rating - have a tolerance of only 20%.
You might do better to replace it with a polyester or polystyrene type - they are physically big in comparison, and more expensive, but last forever.
Steerpike's Toybox |
| Help To Identify Capacitor Functionality | richloh | Car Audio | 8 | 2nd April 2009 09:02 AM |
| Is this a ceramic capacitor - help identify | hafp | Parts | 2 | 24th March 2009 06:51 PM |
| need help to identify this capacitor | milen007 | Parts | 10 | 28th April 2008 04:24 PM |
| Identify this film capacitor ? | ashok | Parts | 2 | 16th July 2007 04:02 PM |
| Identify this capacitor? | adhoc | Parts | 8 | 12th December 2006 10:59 AM |
| Page generated in 0.09161 seconds (76.90% PHP - 23.10% MySQL) with 10 queries |
