Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th November 2009, 06:22 AM   #1
weinstro's Avatar
Default PCB Header/Connector Advice?
I'm building a PCB, roughly based on a Leach. However, I'd like to have the input and VAS sections on one PCB, and the predriver, driver, and OPS on another board.
The idea is to use mating pcb mounted headers to connect the boards and provide mechanical mounting. Any suggestions on pcb mounted header/connectors to use?
Old 30th November 2009, 06:35 AM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
Any of the 100-mil grid type connectors would probably work. If you're working with higher voltages or are worried about capacitance between adjacent pins, you can always skip every other row.
Another solution would be to align the holes in the VAS PCB with those in the output PCB and just run a standard Molex connector with some wire between the two. That way you can adjust the height between the boards by choosing different standoffs. It might give you more flexibility.
I'd run the high-current supply runs directly to the output/driver board and have a separate run for the VAS PCB. This would limit the connections between the VAS and output boards to just a couple.
~Tom
Old 30th November 2009, 07:38 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
My advise is that you have one single pcb.
/Per-Anders (my first name) or P-A as my friends call me
Old 30th November 2009, 12:04 PM   #4
weinstro's Avatar
I hear you. But then I was planning on trying different input, VAS, and feedback circuits, which could simply be plugged in. A key feature would be keeping the connections short.
Old 30th November 2009, 12:55 PM   #5
peranders's Avatar
A pin header is good.
File Type: jpg 1d0dc680-7932-11dc-9199-0019bbdf5d02.jpg (79.0 KB, 59 views)
File Type: jpg daf86b80-78cb-11dc-bb36-0019bbdf5d02.jpg (50.4 KB, 58 views)
Old 30th November 2009, 02:18 PM   #6
jackinnj's Avatar
You can get the gold plated Molex 0.100" headers from Digikey. They can also make up ribbon connectors with any combo of male, female and solder tail connectors. It isn't difficult to make the female connectors -- and I use CAT5 cable or microphone cable.
Good for prototyping -- but the best connector is no connector.
Old 30th November 2009, 04:58 PM   #7
weinstro's Avatar
I'll give the Molex a look, but want to avoid something that requires a cable.
Thanks for posting the pictures.
I was looking at a Harting #09062152821. Looks nice, but each end is $9 or more. The pin header sounds more appropriate.
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 08:21 PM
Header connector, ANGLED and with long (high) pins peranders Parts 3 2nd November 2007 02:28 PM
Computer fan header jwb Parts 3 3rd May 2004 06:18 PM
Page generated in 0.09211 seconds (75.46% PHP - 24.54% MySQL) with 11 queries
