Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Parts chanel (&quot;<img .49&quot;) speakers
Old 3rd December 2009, 01:38 AM   #11
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Originally Posted by 553shee View Post
on the specs of the speakers on that provided web site it says the speakers are *Znom: 8 ohms *Re: 7.50 ohms.
I wouldn't trust that the impedance on PE's website is the same as your speakers. Do you have access to a multimeter? And are the part numbers the same on all 64 drivers?
Tim
Old 2nd October 2013, 01:20 AM   #12
553shee is offline 553shee  United States
this project has been put on the back burner for far too long, now its time to try and get my project on and in the wall.
I am going to purchase a 7.1 reciever first, any thoughts? im not looking for super duper top of the line, just something middle of the road that will do what it needs to do.
front R and L speakers as well as center will be in the wall, side R and side L will be mounted in the ceiling, as for the rear speakers I was thinking of putting them in the ceiling also or I can put them just as easy into the rear wall. so would it sound better in the rear with speakers in the ceiling facing down to the floor or in the rear wall facing twards the front speakers? will the speakers in the rear wall cause a bad sound effect?
Old 4th October 2013, 10:56 AM   #13
triode_al is offline triode_al  Netherlands
triode_al's Avatar
You can try the Totem Pole speaker made by Jean Hiraga with these.
see: L'enceinte Totem (J.Hiraga) (in French but the pictures as always are self explaining)
He used 12 in a series/parallel connection. This is an open baffle of course and has a special form for the bass.
As your speaker looks a slightly bit smaller than the 4 inch Fostex you can of course increase the number . . . to 20, 32 if you like.
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anzai Za´ka (WE91 & 6SJ7); --> FE120 TQWT
Old 6th October 2013, 09:08 AM   #14
How do I test to see how many watts each speaker has? lets say I use 8 of these speakers and hook them up in parallel and series to make a single 8 ohm load, would it be the same concept for watts? 8 25W (for math simplicity) = 200W would it cut the watts 3/4 to 50W?
Old 6th October 2013, 07:01 PM   #15
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
There is no standard for specifying power handling -- hence it is sort of meaningless.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Parts chanel (&quot;<img .49&quot;) speakersHide this!Advertise here!
70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. facundonu Multi-Way 34 9th March 2009 04:59 AM
12&quot; &quot;guitar&quot; driver in Audio Speakers jwhit67 Multi-Way 4 11th February 2008 02:47 PM
does anybody have an layout for anthony holtons "n-chanel" mosfet amp?? hifi Solid State 0 5th October 2001 09:39 AM
Copyright ©1999-2017 diyAudio
