Output transformer cores - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th November 2009, 04:41 PM   #11
Originally Posted by kevinkr View Post
OT:
Jacque Merde.... As a user id, clever...
Now we can say we *DO* know him...
cheers,
Douglas
the Tnuctipun will return
Old 20th November 2009, 05:08 PM   #12
Originally Posted by Mario Pankov View Post
What I found so far is a material called Metglas Magnetic Alloy 2714 which shows superb qualitues - it has the lowest core loss -- To me it looks like the ideal core material, any thoughts?
Lundahl offers an amorphous core in their top transformers - see Lundahl Transformers, audio transformer and tube amplifier transformer manufacturer
Here is what they say about the difference with regular M6 cores of the same size:
"The obvious measurable difference between our silicon-iron cores and amorphous
cores is that the saturation flux for the amorphous core is approximately 33% less than
for the silicon-iron counterpart. This is caused partly by a lower saturating flux level,
partly by a smaller fill-factor due to the thickness of the amorphous sheets.
As a result, power bandwidth is reduced with about 50%. (This means that if the max
output power for a standard LL1620/40mA is 25W at 30 Hz, corresponding max.
power for LL1620AM/40mA is 13W.)"
I don't know what amorphous alloy they use - perhaps Per Lundahl will be willing to email you about it.
Best wishes.
Francois
Old 21st November 2009, 01:21 AM   #13
Jacques Merde's Avatar
cheers,
Douglas
Yes, but do you understand him?
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken
Output transformer cores Mario Pankov Parts 1 19th November 2009 02:24 PM
Russian Transformer cores Jaime Tubes / Valves 4 5th November 2007 10:39 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
filling air gap in transformer cores maudio Parts 22 24th June 2006 01:19 PM
Transformer wiring with different cores rtarbell Power Supplies 3 20th January 2006 07:46 AM
Copyright 1999-2017 diyAudio
