| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have to preface this post by saying that it's my first, and I'm extremely new to the DIY game. With that in mind, please go easy on me if this is a completely boneheaded inquiry or if this post is in the wrong part of the forum.
So I'm going to attempt building my first DIY project, a B1 Buffer Preamp, and I'm hoping to use a spare power supply for my Lenovo Z61t. What I'm trying to accomplish is just be able to plug the existing power supply, unmodified, into the preamp. In order to do this, I'm assuming I'd need to find a compatible DC input jack, which appears to be non-existent everywhere I look on the web. The power supply has a large barrel-type connector with a pin in the center that is unlike anything I can find a receptacle for online. The power supply is this: IBM Lenovo laptop charger/AC adapter/power 20V 3.25A OZ - eBay IBM, AC Adaptors, Laptop Accessories, Computers. (end time 26-Nov-09 00:11:23 AEDST) All that being said, I'm sure I could just cut off the plug at the end and either 1) use the individual wires or 2) reattach an plug at end that is more universal. I guess I just wanted to see if anyone has run into a similar issue/knows where I might be able to find a DC input jack for this particular adapter or can comment on my two proposed alternate solutions, above. Thanks in advance for your patience and any assistance you might be able to provide! |
#2 |
Radio Shack stocks certain of those power connectors - they unfortunately come in a lot of different sizes. have to get both the outer diameter and the inner pin diameter right. MCM electronics has them via mail order.
Charles |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 06:10 PM |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 05:21 AM |
| is there a circuit for a power supply to power the differant add on clocks | frank2395 | Digital Source | 1 | 30th June 2005 10:33 AM |
| selling high current power supply for power amps. | ericpeters | Swap Meet | 0 | 14th January 2005 03:21 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 02:30 PM |
| Page generated in 0.07530 seconds (73.37% PHP - 26.63% MySQL) with 10 queries |
