diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   The CS4398 ... (http://www.diyaudio.com/forums/parts/155116-cs4398.html)
Andrea: 16th November 2009 09:46 AM
The CS4398 ...
is a wonderful DAC chip. It sounds pretty much perfect! :cool:
Especially coupled with a simple one-stage buffer made with the LT1028.
Kurt von Kubik 16th November 2009 10:18 PM
Originally Posted by Andrea: (http://www.diyaudio.com/forums/parts/155116-cs4398.html#post1982344)
The CS4398 is a cool chip, and in addition it is pretty cheap.
To make it really sing, try to pay the utmost attention to its powersupplies.
Fast series regulators for both 5 and 3,3V will improve sound.
Tha analog section can be decoupled with the best caps available with great advantage. We use these: http://www.evoxrifa.com/cap_catalog/generalp/smr.pdf with very good results.
Andrea: 16th November 2009 10:21 PM
Good information, thanks!
What opamps (if any) do you choose to pair with it? I've tried a whole lot... the LT1028 has remained my favorite so far, but there were a few more which paired very well with the CS4398.
Kurt von Kubik 23rd November 2009 10:58 AM
Originally Posted by Andrea: (http://www.diyaudio.com/forums/showthread.php?p=1983106#post1983106)
It is pretty hard for me to recommend any op-amp, since I do not really fancy any of them. But if I had to use op-amps myself, IŽd fit in sockets, so that I could interchange them easily.
Then IŽd try the most interesting ones out, and compare them to a chosen reference, for which IŽd choose NE5534/5532. This is not because I think they are the best, but they are a very well known op-amps with a soundquality way better than their reputation amongst audiophiles.
As a peculiarity, it can be mentioned, that NE5534/5532 in defferent makes and versons, are almost the only op-amp used en pro gear around the world.
So everyone listening to recorded music will know them anyway:D
We did not use any opamps in our analog stage though, we build it completely discrete, and with all discrete power regulations, DC coupling and NFB design was also chosen.
IMHO this is much better than the op-amp solution of various reasons, but design is a lot more complicated.
xslavic 2nd February 2013 04:13 PM
i would dare to recommend opa2277pa but you need to decouple with a cap before right at the output of dac chip and then use LPF active because its only 0.8v/us
Copyright ©1999-2017 diyAudio
