Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th November 2009, 04:04 PM   #1
Default Any recommendations for switches?
I need a double-pole, double-throw to facilitate an HT-bypass function on a passive pre-amp I am building.
I could use a rotary but as there are only 2 states - through the attenuator or direct - a simple push button would seem the best option.
But it needs to be decent quality and I will need to fit some aesthetically appropriate cap on the top.
Does anyone have any suggestions?
Old 14th November 2009, 10:21 PM   #2
Default Switch Recommendation
I have been using NKK switches (available at Mouser.com) - they make nice push button switches that mount in round holes and have flush square or round caps, opaque or illuminated. Check out their catalog at nkk.com --look at their HB, KB and YB series.
Old 14th November 2009, 11:17 PM   #3
sandbasser's Avatar
Mountain Switch also makes some decent switches (they're also available at Mouser).
- Ray
Old 16th November 2009, 07:07 PM   #4
lgreen is offline lgreen  United States
lgreen's Avatar
I've used NKK and Mountain from Mouser. The NKK's are very very nice and there are a lot of options. Go check out their web site.
My DIY audio projects- PartTimeProjects.com.
Switches chipco3434 Parts 1 16th November 2005 07:56 PM
Switches LizardDefence Everything Else 5 1st June 2005 09:52 PM
A simple way to create dual(or more!) rotary switches out of single rotary switches stappvargen Pass Labs 14 17th April 2004 12:33 AM
Illuminated Switches - Recommendations? lgreen Parts 7 5th September 2003 08:47 PM
Using mosfets as switches nobody special Everything Else 8 3rd December 2002 01:35 PM
Page generated in 0.09127 seconds (75.01% PHP - 24.99% MySQL) with 10 queries
