| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Can I get a recommendation on a small signal BJT (in a small form factor like SOT-323) that has a low noise figure? That would work well in a mic preamp. I have played with BC847 and MBT3906. Thanks in Advance
#2 |
Electrons are yellow and more is better!
Why so small?
SSM2210 and SSM2220 from Analog Devices are good but comes in a larger package.
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
um, what type of mic? what impedance, level, location in signal chain?
a ribbon or dynamic is different from a condenser capsule is again different from a buffered electret |
#4 |
I use these in To-92 but might come in other Form factors , BC549, BC550 , They are low noise , come in 3 different gain catagories , are cheap and are used in a Lot of discrete preamps and discrete opamps ....
http://www.fairchildsemi.com/ds/BC/BC550.pdf Cheers |
#6 |
The THAT 300 series?
#8 |
Thanks, I using a balanced electret mic and the NPN is used for bias – a traditional capacity multiply circuit. I found a few low noise candidates and it looks like Fairchild specs the NF on their BC850 at 1.4 dB (max 3dB). In turn, this is feed into a balanced gain stage where I’m using a dual OP AMP. So far I’m looking at BB’s OPA2350 and OPA2132. The reason this is so small is that I would like fit all of this into a mic assembly.
#9 |
Ok,
Just learning how the Post Reply works... Sorry for the repeat message. Thanks, I using a balanced electret mic and the NPN is used for bias – a traditional capacity multiply circuit. I found a few low noise candidates and it looks like Fairchild specs the NF on their BC850 at 1.4 dB (max 3dB). In turn, this is feed into a balanced gain stage where I’m using a dual OP AMP. So far I’m looking at BB’s OPA2350 and OPA2132. The reason this is so small is that I would like fit all of this into a mic assembly. |
| Low noise transistor and noise figure | Real_Macgyver | Solid State | 26 | 31st January 2011 02:34 PM |
| anyone tried this for low noise 5v? | mlloyd1 | Digital Source | 1 | 25th May 2006 01:06 PM |
| NOISE - RFI and EMI | jackinnj | Everything Else | 9 | 26th February 2005 02:01 PM |
| Noise in DAC | Bernhard | Digital Source | 5 | 21st April 2004 09:22 PM |
| Amp noise !!! Please Help !!! | Ford_V6 | Solid State | 7 | 1st June 2003 04:37 PM |
| Page generated in 0.10264 seconds (75.00% PHP - 25.00% MySQL) with 10 queries |
