| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I need to find some constant current diodes for the LTP collectors on the front end of a pwr amp. They're quoted at 1.5mA and need to be able to handle up to 100v. I can't find any 1.5mA items @ Farnell / RS / Cricklewood. Is there anyone else? Thanks in advance. Justin |
#2 |
Why not build your own out of a FET and a resistor? Cheaper, only two parts, and higher performance.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#3 |
Thanks, SY. I could build a current source like this one: http://sound.westhost.com/ab-f5-2.gif However, PCB space is limited, so it'd have to be kludged in there. I've found that the 1N5302 should do the job and can find them in the UK: http://www.centralsemi.com/PDFs/prod...N5283-5314.pdf
What's the advantage of making one from a Jfet + R? J |
#4 |
Well, one advantage is that you can buy them easily and they're cheaper.
All a CCS diode is is a FET with the gate and source shorted together and running at the FET's Idss. If you use a resistor to bias the FET to a lower current, the drain impedance rises (what you want for a CCS). So, lower cost, only two parts (a FET and a resistor), higher performance... why bother with a CC diode?
#5 |
thermionic, 2SK373 work well in this application. You can set them up for any current up to 5mA.
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman |
| For sale : Constant Current Diode 1N5314, 100V, 4.7mA | housing | Swap Meet | 36 | 12th July 2010 10:38 AM |
| For sale : Constant Current Diode 1N5314 | housing | Swap Meet | 13 | 22nd February 2010 04:56 AM |
| constant current source | hacknet | Solid State | 19 | 13th March 2006 03:46 PM |
| Constant current source -3000V | olvrkrg | Solid State | 25 | 10th January 2004 07:19 PM |
| 12Amp constant current source: OT | harvardian | Solid State | 6 | 12th September 2002 12:38 PM |
| Page generated in 0.08876 seconds (72.99% PHP - 27.01% MySQL) with 10 queries |
