| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
R.I.P.
What info do you need? Sure looks like a 3.3 watt 30 ohm to me, and most likely a wirewound.
Regards, Allen (Vacuum State) |
#13 |
I miss typed... it's 330 ohm, but you think I got it right? It was on a Pa amplifier pre-amp board and I am wanting to replace it. I just want to know what would be a good sub for it.
I was considering this; http://www.westfloridacomponents.com...+Resistor.html Last edited by Mace_Hacker; 2nd November 2009 at 02:26 PM. |
#14 |
Just replace it with one of equal resistance and the same or greater power rating. I would recommend going one power rating higher (5w resistors are common and cheap) to guard against future problems.
Not sure why there is an automotive grade component in a preamp, though.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#15 | |
This is the preamp board section. You can see signs of overheating around two resistors at top center of picture.
| Page generated in 0.06811 seconds (81.44% PHP - 18.56% MySQL) with 9 queries |
