Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Why NASA has to buy Russian rocket engines:
Old 24th October 2009, 04:48 PM   #1
vuki is offline vuki  Croatia
vuki's Avatar
Default Why NASA has to buy Russian rocket engines:
POCKOCMOC (Roscosmos) thinks the green one is 10W resistor.
NASA thinks the gold one is 50W resistor.
Seriously, does anyone has some more info on those russian power resistors? I can say that leads are magnetic, but resistor body is not.
Old 24th October 2009, 05:04 PM   #2
Michi124 is offline Michi124  Germany
Michi124's Avatar
The size relations of those two resistors will look a bit different
when you add a 12" x 12" x 0.059" thick aluminum panel to
the Dale resistor, which is needed to make it survive its 50W
power rating. It's all in the datasheets...
Brutalized by bass
and terrorized by treble...
Old 25th October 2009, 08:11 PM   #3
vuki's Avatar
Obviously it was a joke...
But since you seem to be good with datasheets, you wouldn't have the data for the green one, would you?
Old 25th October 2009, 09:06 PM   #4
defect9 is offline defect9  Ireland
defect9's Avatar
are you sure it's not made out of candy?
Old 25th October 2009, 09:12 PM   #5
vuki's Avatar
Quite sure... tried to cut one in half but couldn't do it with "dremel".
Old 29th October 2009, 01:54 PM   #6
alexberg is offline alexberg
alexberg's Avatar
Default Resistors
Ceramic encapsulated carbon comp. TBO [t-v-o] Near extinction type.
http://www.reom.ru
Can be 60 W rated.
Low inductance, huge overload tolerance.
One shall recall Little Devils, which are epoxy encapsulated.
Google picture of the first American satellite insights.
Dale resistors are the wirewound ones - inductive - no good for anything but DC.
As it was correctly noticed, they do require external heatsink...
Counterpart С5-47
BTW It has nothing to do with space exploration and low price on Energia rocket engines, namely RD-180,
Old 29th October 2009, 03:00 PM   #7
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
So that gold one can operate on higher temp than the green one? Probably the gold one is build from better materials.
jd
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 29th October 2009, 04:28 PM   #8
russo is offline russo  Portugal
jd
Dont think so, it is smaller, but without heatsink you wont get any 50w rating out of then, maybe not even 10w
Old 29th October 2009, 04:45 PM   #9
kevinkr's Avatar
RH-50: Actually about 12W without heatsink.. Derating further is a good idea however.
See here for full details on latest Vishay product: http://www.vishay.com/docs/50013/rh.pdf
These are actually pretty rugged and stable resistors. I use them a lot in my designs. There is also a non-inductive type available.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 29th October 2009, 09:55 PM   #10
vuki's Avatar
Thanks alexberg!
Why NASA has to buy Russian rocket engines:Hide this!Advertise here!
Spice simulator engines rtarbell The Lounge 1 26th July 2007 11:17 AM
Spice simulators and their engines rtarbell Everything Else 3 10th July 2007 01:03 PM
Rocket Science PeteMcK Multi-Way 3 4th July 2005 09:41 PM
Copyright ©1999-2017 diyAudio
