| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
anyone know where to buy audionote solder?
thanks a lot |
#2 |
anyone know?
#3 |
You might try asking over on Audio Note's kit forum on AA: Audio Note Kits Forum
Jim J. |
#4 |
why Audionote's? Is it Eutectic? Is it a triple eutectic? Does it erode copper bits? Does it corrode PCBs/tracks/components if not washed? What is special that you require? If it's lead free, then avoid it. If it doesn't wet well, then avoid it. If it needs higher temperatures, then avoid it.
regards Andrew T. |
#5 | |
thank you ,i will try
#6 | |
Hi Andrew i don't know the specific character of AN solder ,but i get an info if the have excellent sonic quality.thanks for the info |
#7 |
if your chosen solder makes assembly difficult and/or makes the assembled circuit less reliable, then what does the sound quality matter if the equipment cannot play anything due to damaged components/PCB?
regards Andrew T. |
#8 | |
Hi Andrew of course,non damaged components is more important ,i'm just using that solder such on female rca in/out,on hard wiring circuit,etc,but for soldering like on pcb,i'm using solder which easy for flow,such cardas and wbtthank you |
#9 |
tomat, you understand that these guys don't actually make solder, they just take some standard product and mark it up? Lead and tin atoms don't change just because of a name on the box and a fancy price.
If you're soldering copper, a 63/37 eutectic will work perfectly. For silver, a 2% silver solder, ditto. And you can have the satisfaction of knowing that you spent that extra money on something useful, like CDs or hookers.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#10 |
Does anyone know who makes (& sells) the Cardas four element (quad) eutectic?
regards Andrew T. |
| Audionote DAC or RAKK DAC | la1209 | Digital Line Level | 0 | 31st March 2009 01:47 PM |
| audionote 144 OPT comment pls... | calico88 | Tubes / Valves | 0 | 13th September 2006 11:02 AM |
| AudioNote DAC 4 SIG. | nafunga | Digital Source | 2 | 10th October 2005 08:44 AM |
| FS : Audionote SE tranny | cm | Swap Meet | 1 | 9th June 2004 07:12 AM |
| AudioNote Dac Kit 1.2 Voltages | PTSOUNDLAB | Digital Source | 12 | 21st January 2004 11:50 AM |
| Page generated in 0.10754 seconds (80.70% PHP - 19.30% MySQL) with 10 queries |
