Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st October 2009, 12:01 AM   #1
Default Need transistor with BD139 specs but higher wattage?
Hello,
I am looking for BD139 substitute with same basic specs except I need much higher wattage (power). Can anybody make any suggestions? Thanks!
Old 21st October 2009, 12:26 AM   #2
Iain McNeill's Avatar
Bit more info please unless a 2N3055 will do.
You need the same pin out and package size?
What supply voltage are you using?
How much current at what supply voltage do you need to deliver?
If you can tell us the application that would help too.
Old 21st October 2009, 04:36 AM   #3
Enzo is offline Enzo  United States
So you are going to make us have to look up the BD139 to find out what those specs are?
Old 21st October 2009, 04:43 AM   #4
http://www.fairchildsemi.com/ds/BD/BD139.pdf
Old 21st October 2009, 05:52 AM   #5
jcx is offline jcx  United States
the obvious solution is parallel more BDs with a little emitter degen for good current sharing
"totem pole" cascading can also work if low Vsat isn't required
Old 21st October 2009, 05:55 AM   #6
Electrons are yellow and more is better!
peranders's Avatar
D44H11 is good if you can take different pinning, normal TO220. What is your application?
/Per-Anders (my first name) or P-A as my friends call me
Old 21st October 2009, 06:12 AM   #7
Ordinarily I would share the sentiment but if you don't know the properties of the BD139 then you can hardly recommend a better alternative, eh?
Old 21st October 2009, 10:28 AM   #8
Elvee is online now Elvee  Belgium
The BDX37 is pretty similar, but has half the thermal resistance of a BD139:
http://www.datasheetcatalog.org/data...lips/BDX36.pdf
It will be difficult to find a much a higher power in a TO126 case.
Old 22nd October 2009, 05:49 AM   #9
"Ordinarily I would share the sentiment but if you don't know the properties of the BD139 then you can hardly recommend a better alternative, eh? "
Well, I don;t know. He isn;t looking for a drop in exact replacement, he is looking for something similar with larger dissipation rating. I am not so sure that not having the characteristics of the particular part in my head disqualifies me from doing here what I have to do on a regular basis on my bench - come up with a reasonable substitute for a part.
if it is a secret, then I guess I will never learn those properties, and will never be able to offer a useful insight. My work is largely in pro audio, and we don't see so many transistors from the BD series, we mainly see American numbers and Asian numbers. But I think consumer audio works in similar fashion.
Thanks.
Old 22nd October 2009, 06:28 PM   #10
Hi, can you tell me what you are using it in or what it is for, nobody has asked you this. I used to use these in my diy amplifiers back in the 80's, but if my memory serves me correct i used a BD711 or BD712 but I had to turn it round as I think the Base and Emmiter is opposite to the BD139.But there are other factors eg - is it mounted on a heatsink.
I hope this helps - Let me know
Anthony
KEF BD139 passive radiator specs? Joschl Multi-Way 10 30th December 2008 10:33 AM
Does preamp wattage effect power amps wattage? JonnySwitchblade Solid State 7 4th July 2007 04:18 AM
Transistor specs. Help!...do you know those units? destroyer X Solid State 9 11th September 2005 12:25 PM
2SB1353 Transistor specs? Chris Daly Solid State 8 27th September 2004 03:47 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 05:01 AM
Page generated in 0.13420 seconds (71.97% PHP - 28.03% MySQL) with 10 queries
