Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th October 2009, 08:05 PM   #1
Default quad ganged 50k linear poti...
I want to build Cyril Batemans notch filter. Therefore, I would need a good quality (plastic?) Poti wit 4 levels. Anybody knows who sells??? I don't want an extremely expensive "high-end" pot - just good quality. It shouldn't be to big as well...
Please give me your part comments...
Dirk
Old 16th October 2009, 02:19 AM   #2
Bigun is offline Bigun  Canada
Bigun's Avatar
You can, if you want, make up a 4-gang from high quality Vishay pots:
TGM Amplifier ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 16th October 2009, 11:28 AM   #3
Yes, you think of Vishay 9A (plastic) and 9P (cermet) Types... Which is superior? Cermet or plastic?
I see a problem with the right axis - if I use a stereo lin pot, I would need a longer axis. Where could I get it? (I think, screws will not be troublesome...)
Dirk
Old 16th October 2009, 11:45 AM   #4
Geek's Avatar
You're looking for the Noble V12L5 series or the like, maybe?
Cheers!
Old 16th October 2009, 12:10 PM   #5
Hi Geek,
it's for a measurement app, so the vishay shows more appropriate...
Regs, Dirk
Old 16th October 2009, 01:03 PM   #6
gagnou is offline gagnou  Greece
gagnou's Avatar
I used this:
4,Panel Mount PCB Dual Triple-Deck Linear 50k Pots,P001 - eBay (item 300357248095 end time Oct-21-09 00:19:34 PDT)
Out of the four in the lot I found one with relatively good tracking.
Cheap and adequate for the job.
George
Old 16th October 2009, 01:24 PM   #7
thanks, but it won't fit on the pcb... ;-(
Old 16th October 2009, 01:26 PM   #8
@geek: it's not linear, seems car audio stuff...
Old 16th October 2009, 01:27 PM   #9
anyone knows where I could get the quad ganged vishay???
Old 16th October 2009, 08:35 PM   #10
Geek's Avatar
Sorry about that, I just saw that in the datasheet
Cheers!
Quad-ganged pots? Minimum40 Car Audio 6 29th August 2006 11:47 AM
6-Ganged Potentiometers? EchoWars Parts 36 24th August 2003 09:51 PM
6 channel ganged pot daatkins Parts 11 30th October 2002 05:55 AM
Page generated in 0.09642 seconds (74.83% PHP - 25.17% MySQL) with 10 queries
