| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
i am seekeing to buy a couple of the Toshiba optical diital interfaces TOTX142L and TORX142L, but it seems the components have become obsolete and no one is carrying them anymore. If someone has a cople spares or a source where to get them, I be very grateful. |
#2 |
#3 | |
Go to digikey.com or mouser.com and get the replacement, Torx147 at around 1,5 USD |
#4 |
Thanks for the replies.
#5 |
Checking the datasheets, at least as far as the receivers are concerned,
the TORX142L appears to be rated for higher data rate. This would be concern if trying to pass 192kHz sample rate. http://media.digikey.com/pdf/Data%20...s/TORX142L.pdf http://sigma.octopart.com/49088/data...RX147(F,T).pdf Therefore, being that the 142LF is no longer available, the kit through Twisted Pear may be only option (if 192kHz is desired). At least the Twisted Pear kit comes with small board and support components if you want to install into existing equip. where there is no way to install totally new circuitry with receiver integrated on board. Gee, where to get the high speed transmitters, though? |
| Page generated in 0.07299 seconds (72.83% PHP - 27.17% MySQL) with 9 queries |
