| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Has anyone ever heard of a Reverbertron 2, Fairchild model 658B? Someone gave this to me thinking I could use it for my guitar.
I did a search on the web and it turned up nothing. I'm looking for specs and diagrams on how to wire up the back. Any help would be great. Gregory K. |
#2 |
This is why I don't know how to wire it up.
#3 |
Fairchild made some of the most coveted audio gear ever made. I was once GIVEN a Fairchild compressor to use in a TV station where I worked. It was actually the first compressor I had any real time to play with. The whole time I had it I was bummed that I couldn’t adjust the slope, but didn’t mind so much because it sounded great. Years later I found out that it was worth around $10k! Wish I had it today.
I don’t know much about what you have, but I would guess that it is just the control panel for a spring or plate reverb chamber. |
#4 |
Hi, I have a Reverbertron II Model 659. I realise this is an old post, but as the post above states this is just one module from the "head unit" of a Reverbertron. The Head unit would then be wired to a seperate rackmount spring chamber.
#5 | |
Thank you. |
| fairchild find? | tinkerbell | Solid State | 9 | 28th April 2012 02:26 AM |
| What is D65AB from Fairchild? | stef1777 | Parts | 0 | 29th November 2007 12:22 PM |
| Fairchild amp application | blink | Solid State | 12 | 15th December 2005 10:45 AM |
| Fairchild IRF540A | richie00boy | Parts | 8 | 22nd June 2004 11:39 AM |
| Fairchild IRFP | NHul | Pass Labs | 0 | 16th February 2002 09:12 AM |
