| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#31 |
Using ZIF sockets is a nice idea but you'll need one on your programmer and one in your target board (your prototype).
40 pins ZIF sockets aren't cheap. Using ICSP (In-Circuit-Serial-Programming), you only need those pins : GND, +5V, RB6, RB7 and /MCLR. This way, you don't need to remove and insert your chip all the time. As you probably know, Microchip ICD schematics are available on their website so why not use them ? i found on the following site a complete ICD projet with PCB, instructions etc... You don't want to miss that link. Here's the original version of the previous link with color pictures http://membres.lycos.fr/silicium31/E...C/free_icd.htm Take a look, you won't be disapointed. Regards, |
#32 |
been surfing:
it seem like there is a hundred variants of each parallel port/serial port PIC programmer out there. I suspect people could not understand each others diode-cap-zener combos to create the required +5 and +12 most seem to be PC port dependant the real RS232 spec on a serial port is huge 3-25v, thus the variants If you have a desktop PC keep in mind these voltages ara available on a HD connector. I am leaning towards designs with an external (HD?) power - seems much more reliable. low voltage programming looks like you give up a pin, which seems restrictive to me if I was going to buy one the picflash USB or clone seems to have a future if i was building for simplicity - the ludipipo w external supply is like 3 resistors. period. ludipipo and jdm and jmb and c84 all seem to use the same rs232 pin assignments. ic prog seems like a strong programmer supports most hardware , lets you tweak comments? edit-I see lots of complaints about the el-cheapo (predko), cuz there are so many or the architecture?
intentionally blank |
#33 |
Mine is -11.15v on pin 7
what? |
#34 |
check the microchip site for free seminars
grumpy cuz I didn't win the free usb programmer
| Up to date PIC programming | TroelsM | Everything Else | 4 | 6th May 2009 08:54 PM |
| microcontroller programming | traf | Digital Source | 7 | 12th September 2007 12:49 PM |
| C Programming problem | FuriousD | The Lounge | 1 | 1st December 2005 09:38 PM |
| PIC programming | serosmaness | Digital Source | 12 | 6th February 2005 10:33 PM |
