Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th September 2009, 03:48 PM   #1
Default Polyester or Polypropyolene. Which is which?
I have a quantity of the caps shown in the photo below. Some are polyester and some are polypropylene but I cannot remember which is which.
Caps numbered 1, 4 and 5 look like polypropylenes, with the rest being polyester.
Can someone confirm this or correct me?
How does one differentiate the two types of caps?
Many thanks.
Old 20th September 2009, 11:58 PM   #2
No answers? Was this a stupid question?
Old 21st September 2009, 01:15 AM   #3
jackinnj's Avatar
No, it isn't a stupid question. You'll need a really great impedance meter like an HP or Gen Rad to measure both the impedance and dissipation factor.
Old 21st September 2009, 01:52 AM   #4
BrianDonegan's Avatar
You can make some educated guesses...
Polyprop caps are generally larger for a given value. For example, the 2.2uF is definitely a polyester cap.
Old 21st September 2009, 07:49 AM   #5
Oh well, thanks anyway guys. Cheers!
Old 21st September 2009, 08:16 AM   #6
hasaudio.co.nz's Avatar
Yea I dont think you can really tell from the outside. As Jack said you need a descent Impedence meter to determine that.
Hasaudio Speaker Components
Old 4th October 2009, 05:41 AM   #7
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
The quick and dirty test I use for capacitors is to charge the unit to, say 10 volts, then short the terminals for several seconds, wait a minute and then measure the remaining voltage with a high-impedance voltmeter. Polypropylenes will have a significantly lower residual voltage, though measuring lower-capacitance units gets tricky.
Old 4th October 2009, 06:04 AM   #8
analog_sa's Avatar
This has been discussed before and is really fast and simple. Polyester has a positive tempco and polyprop negative. Use a hair dryer and capacitance meter and you'll have the answer in seconds.
Old 4th October 2009, 12:16 PM   #9
SY's Avatar
Nice trick, I didn't know that! My method, much less elegant, is to destroy one, unwind a bit, then ignite with a cigarette lighter. PP smells like a burning candle, PE smells slightly sweetish.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 4th October 2009, 12:20 PM   #10
MJL21193's Avatar
My trick is to not worry about it.
Differences between polyproprolene and polyester capacitors darren01 Analogue Source 5 31st July 2004 01:13 PM
polyester vs metal film caps Wagener Solid State 1 8th May 2004 09:13 AM
Is this SMD Metallized Polyester Film Cap any good? Brian Guralnick Parts 10 10th October 2003 08:57 PM
Black Gate N or Polyester Whit Parts 1 16th April 2003 08:02 PM
Page generated in 0.10077 seconds (77.68% PHP - 22.32% MySQL) with 11 queries
