Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
motor run caps
motor run caps
Old 16th September 2009, 11:30 PM   #1
grahamb is offline grahamb  United Kingdom
Default motor run caps
Anyone know of a uk supplier of oil filled polypropolene motor run caps?
regards grahamb
Old 17th September 2009, 02:18 AM   #2
lowtherdream is offline lowtherdream  Canada
lowtherdream's Avatar
http://www.maplin.co.uk/module.aspx?moduleno=30309
http://www.discountelectronicsstore....ors/motor-run/
http://www.vtm.co.uk/index.html (they carry Aerovox)
http://www.aerovox.com/products/shop...categories.asp
I'm not from the UK... just trying to help
surfing the 2nd harmonic ... @@@@
Old 17th September 2009, 08:08 PM   #3
andyjevans is offline andyjevans  United Kingdom
I'd buy direct from LCR if you can deal with the minimum quantity - from memory it's about £100 but it's a lot cheaper buying direct.
http://www.lcrcapacitors.co.uk/
Old 17th September 2009, 11:14 PM   #4
Matt BH is offline Matt BH  United Kingdom
Check RS. If you type RSwww into your search engine you will find them. I would give you a link direct to an apropriate page but I am currently on less than dial up (20K ouch). Not my network some particularly annoying virus.
Also try your local electrical factors. Mine is Rifina and they stock a good range of motor caps at good prices. Dont bother with CEF they are hopeless, I am forced to use them as we have an account. I have trouble getting something as mundane as a 6mm bolt sometimes.
Anyway most electrical wholesalers stock motor type caps.
Cheers Matt.
motor run capsHide this!Advertise here!
Motor run Caps Question Fat Daddy Parts 4 3rd May 2008 10:55 PM
ESR of motor-run caps? JoshK Parts 12 14th December 2007 03:17 AM
Motor caps croccodillo Parts 13 1st December 2005 12:44 AM
AC Motor Start Caps for PS use gilid Parts 44 28th June 2004 11:35 PM
