Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
28 cheep cirrus logic digital audio recievers
Old 14th May 2003, 09:05 PM   #1
bigparsnip is offline bigparsnip  United Kingdom
bigparsnip's Avatar
Default 28 cheep cirrus logic digital audio recievers
Hi, I found these going on ebay, and although I would like to build a DAC, I'm in the middle of trying to get my pre and power amps done first, so if anyone else wants them, have a look;
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=2529717240
Also, you can find the data sheet for their replacements below, the only diference is that these ones will not work at 96kHz input, but that is mentioned in the data sheet.
http://www.cirrus.com/en/pubs/proDatasheet/8413-4.pdf
Old 14th May 2003, 09:22 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
We need a datasheet for the actual device to see if it's DIY usefull.
The previous '11 receiver needed a serial interface to control it.
And why is it obsolete so quickly? Was there a problem?
Old 14th May 2003, 09:30 PM   #3
bigparsnip's Avatar
the chips in the data sheet are pin compatable with the CS8411 (well the CS8413 is, the other one is a replacement for the CS8412), the only diference between the models is that they have added the capability to receive 96kHz PCM data, and they canged some fo the output codes to identify this new mode of opperation. Otherwise, as far as I am aware, the chips function in exactly the same way, so you can design from the CS8413 datasheet, but not use the higher data rate signal.
Oh, one more thing, just because the reciever can't decode the 96kHz PCM data, it can still be used for an upsampling DAC, just as long as the input signal is comming from a source operating at 44 or 48 kHz.
I think.
Old 14th May 2003, 09:32 PM   #4
bigparsnip's Avatar
Sorry, forgot to mention, if you look on page seven of the data sheet it tels you the differences between the models.
Old 14th May 2003, 09:35 PM   #5
bigparsnip's Avatar
Me again, I found a coppy of the correct data sheet, not on the cirrus website, but still the right thing I think. You'll find it below;
http://www.lcaudio.dk/comp/cs8412.pdf
Old 14th May 2003, 09:47 PM   #6
dhaen's Avatar
Default Thanks for the link...
Hmm, so is it useful without a processor?
Someone with superior computing power is required...
Old 14th May 2003, 09:49 PM   #7
bigparsnip's Avatar
Didn't notice that one, but I guess it couldn't be too hard to get a PIC chip up and running to do the job, especialy if you had enouugh of the things to do 28 boards.
Old 14th May 2003, 09:58 PM   #8
dhaen's Avatar
Default Hold on....
I'm not saying it's not feasible. Just not feasible for me (old codger who last wrote code 25 years ago)
BTW what's with the parsnip? and why is it big?
Old 14th May 2003, 10:02 PM   #9
bigparsnip's Avatar
Not as bad as it sounds. I am about 6foot three and I have ginger (not red tough ) hair. A while ago, when I was still at school I started arguing with some people who decided to call me a carrot (I'm a little pedantic at times). Arguing that carrots are orange on the bottom, with green on the top, so surely by thier logic I looked more like a parsnip, as I was white, not orange on my bottom half. And it just stuck (to be fair these people were my friends, and it was all my own fault), but I always seem to be able to sign up on forums using that name, so it's kinda useful.
Old 14th May 2003, 10:06 PM   #10
dhaen's Avatar
I'd better not argue with you then. You've got 4" over me
28 cheep cirrus logic digital audio recieversHide this!Advertise here!
FS: Cirrus Logic CS8416 Evaluation Board ralphs99 Swap Meet 3 17th March 2009 11:20 PM
FS: Cirrus Logic CS5381 Evaluation Board ralphs99 Swap Meet 3 16th March 2009 11:15 AM
CS8414 Cirrus Logic chip? Mrstereo Parts 0 27th March 2007 07:32 PM
source for cirrus logic (crystal) chips bongo1 Parts 0 7th March 2005 09:13 AM
Cirrus Logic CS4328 DJ_Looly Parts 0 2nd November 2004 10:37 AM
