Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th September 2009, 08:57 AM   #1
jazz is offline jazz  Netherlands
Default Q about deriving cap specs
I've got a bunch of big old electrolytic caps lying around I want to use in the psu of some prototype builds. To try and have some understanding of what I'm doing and how to rate parts I want to try and simulate using psudesigner.
The problem is I have no specs on the caps other then what's printed on them. The print states the following:
33.000uF (-10/+50%)
UN 40V
-40/085/56 type1
Ieff. (100Hz) 30A (50deg.C)
Is there a way I can deduce the ESR from that?
Thanks,
Joris
oh, what a beautifull day
I wanna go out and play!
Old 12th September 2009, 04:26 PM   #2
Tech is offline Tech  United States
Tech's Avatar
You're wanting to see about checking if the capacitors are good? If so, I wouldn't worry about those old caps. I'd be more concerned about what your actual capacitance values are under that huge tolerance.
Old 15th September 2009, 05:03 PM   #3
It may be overkill for your requirement but for anyone else reading this thread, I've found a capacitance meter such as the PEAK Atlas ESR Capacitor Analyser to be very helpful.
Here's the link: http://www.peakelec.co.uk/acatalog/jz_esr60.html
Old 16th September 2009, 05:51 AM   #4
Thanks for the responses. I don't worry about them being good or not as much. They work and that's enough for the purpose. I was just wondering about deriving esr from the printed specs for simulation purposes.
For the rest I just reformed them (leakage current check) and measured capacitance. Then I put them in the circuit and pressed 'fire'. Nothing blew up (unlike the first time when I used them without bypasses and blew up a few bridges...).
regards,
Joris
deriving T/S parameters from common specs hitsware Full Range 8 5th January 2009 02:12 AM
Deriving WS from a 24.576MHz clock? Lovan Digital Source 6 15th November 2006 03:44 PM
Deriving I2S from Sony CDP Peter Daniel Digital Source 59 3rd June 2006 09:16 PM
Deriving I2S from Philips LHH CD players ... deskmate88 Digital Source 0 7th June 2003 07:45 AM
Page generated in 0.06634 seconds (71.21% PHP - 28.79% MySQL) with 10 queries
