| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#81 |
Banned
I guess I should grab a Rubycon ZLH and see if it has magnetic leads or not...
#82 |
Bitter, but true. Panasonic FC do have tinned copperclad steel wires - easily tested by using a magnet.
/alohka/ |
#83 |
Tried out a few caps and other components with a powerfull neodynium magnet.
Panasonic FM = magnetic Sanyo OSCON = magnetic Nippon Chemi ASW & ASF = non magnetic BC Components light blue electrolytic cap = magnetic BC components special film cap of some kind = magnetic Wima MKS, MKP and more = non magnetic Evox PP cap = non magnetic Phillips and NS NE5534/5532 = magnetic So iron must be present in the leads in some way. Btw. the most obvious reason for using iron in leads is strength. I´ve tried to scratch the tin away from the leads on some capacitors, and always found copper underneath. But it is obvious that also iron is used in some caps.
Just do it
#84 |
Magnetic leads enable automatic insertion of components into PCB.
#85 | |
I do try when possible to purchase passives made with non-magnetic materials for things that are directly in the audio path, and don't bother much elsewhere.
www.kta-hifi.net |
#86 | |
www.kta-hifi.net |
#87 | |
So if low ESR @ all frequencies is wanted, you can go for the cap with the best ESR data regardsless of materials used. I also think that the solder itself is a somewhat bigger problem than the leads are.
Just do it
#88 | |
diyAudio Moderator Emeritus
Why do you do that? Kind regards, Bas |
#89 |
Banned
So I see that the film caps (e.g. Wima) have non magnetic leads.
So it's even more reason to use bypass caps in power supply, no? I found that MKP Wima's improved the sound a lot in my DAC's analog stage power supply, as compared to just using Panasonic FM & FC's. They made things sound smoother and more colorful. |
#90 | |
But choose to bypass just beside the component to be power supplied. Not at the main smoothing caps, but so that every single powerneeding component only sees one bypass. That is in my experience the way to do it. And you are right, good bypass caps makes the sound more natural and smooth. Try also Evox SMR polyphenylene sulfid caps. Wima also makes these types, but I´ve never succeeded in coming across them. However the Evox types should work just as well. From a technical viewpoint these polyphenyl sulfid caps is superior to PP and polyester, from a sonic point of view they completely crushes the competition. I´d very much recommend them, and btw. they have copper leads. So far I´ve only tried them out as decoupling/bypass caps in a discrete DAC design, and only for analog purposes, more precisely on the analog side of a CS8416, on the analog side of CS4398 and in discrete series regulators as well as in shunt regulators, in the latter not for decoupling, but for filtering purposes. They came in as substitude for Wima MKP caps And the result was very surprising. I´ve always regarded Wima caps as some of the best ones, as well as evox, BC components, Panasonic and others, and they surely are so, but I just wonder why only Evox recommends these types for audio. Maybe this is because "audio purposes" normally are regarded inferior to almost anything else. Automotive, aerospace, industrial and general purposes, I think is regarded with much more respect and prestige. But never the less Evox has noted, that they are exellent for audio applications to. They also should theoretically be very good for decoupling digital circuits, as they feature low ESR @ high frequencies and very low loss, but they have to be accompanied by ceramics though, which might make them less important in such places.
Just do it
| Lots of NOS Electrolytic Capacitors! | ungie | Swap Meet | 23 | Today 02:45 AM |
| reforming electrolytic capacitors | AndrewT | Parts | 11 | 4th April 2011 09:38 PM |
| 4 pole electrolytic capacitors | AGGEMAM | Pass Labs | 7 | 22nd February 2010 02:58 PM |
| Electrolytic capacitors | akis | Parts | 13 | 16th August 2009 06:13 PM |
| Electrolytic vs polyprop capacitors | Puggie | Tubes / Valves | 2 | 15th September 2005 01:32 PM |
| Page generated in 0.56424 seconds (22.39% PHP - 77.61% MySQL) with 11 queries |
