| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#61 | |
diyAudio Moderator Emeritus
Modifying audio equipment: recommended components |
#62 |
I'm a big fan of their smaller silver post when paired with the silver spade. Expensive, though IMO still a scorching deal relative to other product on the site.
Edit: looks like CMC makes a silver-over-copper post too at roughly half the AN price.
Ears aren't microphones. Last edited by rdf; 16th November 2009 at 07:51 PM. |
#63 | |
Banned
To me it's disappointing that the various Elna or Nichicon for audio are all specified for 85°C max and with a 1000 or 2000 hours endurance. ![]() The Rubycon ZL sound quite good as power supply caps, anyway. And they last long. It think they sound better than the Panasonic FC or FM. At any rate, wherever possible I prefer to bypass the electrolytic with a small Wima, polyester or polypropylene - just not too small, or it's useless. |
#64 |
What are most of you guys preferring on non-polars for passive crossovers? Ideally, I don't want something prohibitively expensive, as I may grab a bunch of different values to have on hand for testing. I've also got a DigiKey order in the build stage, so if there's a good one they stock, that would be easy, but I can make a second order if not. Much Thanks! |
#65 |
thanks for Kendeil, I wish I could find all the caps in one place like on ebay...
there is one thing left that confuses me a bit It's clear with Nichicon and Elna caps' polarity from the PDF info on Partsconnexion, but as to those blue Philips in my Rеstеk, do they have the same polarity as Elnas - side with "-" is actually + ? Couldn't find anywhere in the net, just a few records on this forum, that they have some tricky polarity ![]() Could anyone advice pls? as to the others black noName caps, the same technique as with Elna, Nichicon?? |
#66 |
How does tan d relate to quality? I'd assumed the lower the better, like DA and DF for film caps; higher voltage small caps have lower tan d and the "audio" caps seem to generally have a lower tan d than others, but not consistently.
Also note that Black Gates never had objective specifications like tan d and leakage, derating factors, etc. But even many audio manufacturers took them seriously enough to use in their better equipment. I'm not clear on what the distortion mechanisms in small caps are, only that the graphite loaded electrolyte in Black Gates seemed to make some sense and there's no equivalent on the market (you'd think someone would be making a knockoff, but I haven't even heard rumors of Black Gate fakes). Electrolytics are hard to figure out from an objective viewpoint, other than we can't get away from having to use them even if just for power decoupling. |
#67 |
Certainly not a rumour. All the Naim pieces i've owned used them. Excellent caps.
#68 |
How do those Kendeils compare to Sikorels?
#69 | |
Pannasonic FM features Copper leads, which all caps do. A lot of them even OFC copper. Btw. the panasonic FM is the electrolytic cap with the lowest ESR anyway. You cannot fit steel to aluminium without a complex proces, så you´ll never find steel in places like that. The coil is aluminium, and in larger cans the terminals are also aluminium.
Just do it |
#70 |
for decoupling and bypassing purposes try out the Evox SMR polyphenylene sulfid caps.
Just do it |
| Lots of NOS Electrolytic Capacitors! | ungie | Swap Meet | 27 | 29th February 2012 02:38 AM |
| reforming electrolytic capacitors | AndrewT | Parts | 11 | 4th April 2011 08:38 PM |
| 4 pole electrolytic capacitors | AGGEMAM | Pass Labs | 7 | 22nd February 2010 01:58 PM |
| Electrolytic capacitors | akis | Parts | 13 | 16th August 2009 05:13 PM |
| Electrolytic vs polyprop capacitors | Puggie | Tubes / Valves | 2 | 15th September 2005 12:32 PM |
| Page generated in 0.11168 seconds (83.31% PHP - 16.69% MySQL) with 11 queries |
