Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
BYV44-400, Transistor or Diode, you decide.
Old 13th May 2003, 08:17 PM   #1
bigparsnip is offline bigparsnip  United Kingdom
bigparsnip's Avatar
Default BYV44-400, Transistor or Diode, you decide.
Hi, I have bought (allong with some other things if you see my other post) some devices off ebay which are marked as BYV44-400. Now, after some serching on google I found information which told me that these things are High speed, high current 400V Diodes (two per package, with a centre common cathode). However, the guy who I bouught them from has told me that they are power transistors.
As he said they were leftovers from a project he had finished, I would like to think that he must be right (otheriwse he might get a bit of a shock - no pun intended - when he plugs it in). However, from everything I have found these things are diods.
So can anyone tell me for sure what these things are. Thanks.
Old 13th May 2003, 08:20 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Diodes for certain.
Every semi produced in Europe with BY at the front has been a diode.
Old 13th May 2003, 08:23 PM   #3
bigparsnip's Avatar
Thats what I thought, well thanks for clearing that up then and I guess I can now rest happy that I have a LOT of High speed rectifier diodes for not a lot of money. Thanks, and if anyone else can provide anymore information on these (a data sheet would be nice) I would be very gratefull.
Old 13th May 2003, 08:37 PM   #4
nemestra is offline nemestra
nemestra's Avatar
Philips have discontinued the BYV44-400 but are still producing the -500 part. Click on the link at the bottom of this page
http://www.semiconductors.philips.co...BYV44_500.html
and download the BYV44 family .pdf which covers the -300, -400 and -500 parts.
James
Old 13th May 2003, 08:37 PM   #5
dhaen's Avatar
Default Wonderful thing, Google...
http://elplus.com.ua/doc/515.pdf
Old 13th May 2003, 08:38 PM   #6
Netlist is offline Netlist  Belgium
Netlist's Avatar
In case you ever want to build something with them:
http://www.semiconductors.philips.co...4_SERIES_3.pdf
/Hugo
Old 13th May 2003, 08:40 PM   #7
Netlist's Avatar
I tend to slow down...
/Hugo
Old 13th May 2003, 10:05 PM   #8
bigparsnip's Avatar
Thanks for those links, but I had beeten you guys to it once dhaen had confirmed they where what I though. But thanks anyways.
BYV44-400, Transistor or Diode, you decide.Hide this!Advertise here!
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 11:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 10:18 AM
OB or TL - Help me decide jim rose Full Range 13 22nd March 2007 10:10 AM
BYV44-400 ultrafast rectifier diodes. bigparsnip Swap Meet 0 6th May 2004 10:11 AM
Copyright ©1999-2017 diyAudio
