Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th August 2009, 02:15 AM   #1
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Question SOT223 cooling?
What the lowest thermal resistance may be obtained if I bolt SOT-223 device on a copper plate?
They are usually rated for 83K/W, is it in case of soldering to a copper clad board?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 15th August 2009, 02:31 AM   #2
Wavebourn's Avatar
Here is an answer from Fairchild:
http://www.fairchildsemi.com/an/AN/AN-1028.pdf
Old 15th August 2009, 04:29 AM   #3
jcx is offline jcx  United States
if you want to stick with conventional smt assembly you can buy smt heat sinks that get the heat off the board much more effectively than just using Cu plane area
http://www.aavidthermalloy.com/cgi-b...ce=14&x=31&y=6
designed for bigger smt pkgs but no reason you couldn't butt a sot223 tab against one of the legs of these heatsinks, probably good for 2-3W
there is still some limit due to j-c thermal resistance that inclues a die size term
http://www.diodes.com/zetex/_pdfs/3.0/pdf/SOT223.pdf
looks like >5-6W would be possible with a chill plate
Old 15th August 2009, 05:40 AM   #4
Wavebourn's Avatar
Thanks JCX, I need 2.5W, and I am free to bolt or solder it to anything I want, so it is not a problem. Cool! BSP225 from Philips rulez!
Old 15th August 2009, 09:12 AM   #5
MaxS is offline MaxS  France
Hello
You already have find great stuff.
But in a case of SMT oven production, you have to know that cooler make soldering harder due to cooling thermal power (destined to solder) from transistor to PCB (I don't know if this phenomena is reproducible on plate) but I want to warn people about that before they go crazy.
MaxS
Ca marche pas ! Tu ne l' as pas branché non plus ....
Page generated in 0.07391 seconds (73.39% PHP - 26.61% MySQL) with 9 queries
