| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I was just ordering some big capacitors and read the notes from the manufacturer (Panasonic) about storage, I thought of sharing :
*************** *************** Leakage current will increase with long storage times. Storage times in ambient temperatures of 40°C or less can be four years or more before leakage current should be checked for conformance to the specified limit. Longer storage times may require reforming of the capacitor to reduce leakage current below the specified limit. This can be accomplished by applying rated voltage in series with a 1000R resistor for a time period of 30 ~ 60 minutes. Under normal conditions, shelf life can exceed 10 years, providing that leakage current is checked before use. ********************* ********************* |
#2 |
I was aware that electrolytics need to be used frequently (charged) to keep them fresh.
It is not good to keep them on the shelf without use. I heard under normal use they have a longevity of about 15-20 years. I recently overhauled a Carver TFM-55 and replaced all caps. (1992 model). |
#3 |
And, if you don't want to tear a device apart, remove all the caps, put a resistor in series with each one at the correct voltage on a DC power supply, etc. A compromise that will work for many things is to slowly power up the device on an AC variac. Start with just a few volts of AC line voltage and nudge it up every so often until you finally get to regular line voltage.
This does much the same thing without all the hassle. It's generally bad to take something that's been in storage for many years and just plug it in and flip the switch--especially an audio power amp with big, relatively high voltage, caps in the power supply. And leakage currents are typically much more of a problem in high voltage tube gear as the voltages are even higher and the higher impedance circuits are often less tolerant of leakage. So all of the above is even more applicable for anything with high voltage power supplies. |
#4 |
Is it ok to use the speakers electro. caps (in storage for + twenty years, in a box) after they were all measured with the meter?
#5 |
How do you measure leakage current on a capacitor (new or old) ? Do you wait for it to self-discharge ?
Here's what they say about it: ******************* Leakage Current I = 3 CV (ìA) maximum after 5 minutes of applying rated voltage. Capacitance is the nominal value in ìF, voltage in VDC. ******************* |
#6 | ||
All electrolytics, however, degrade over time. And most consider their useful life around 10 - 20 years depending on temps, how they're used, etc. Quote:
#7 |
Ehhh, are non-polar not just two reversed polars
They may be just as leaky if old |
#8 | |
And as I said, all electrolytics degrade with time including non-polars. So if you have some really old caps, don't use them. And if you have some really old speakers replacing the caps might be a good idea. These days most think a film capacitor in series with the tweeter sounds better too. And they last a lot longer. |
#9 |
I suppose leaking results in loss of capacitance, and even worse in speaker xo
#10 |
So essentially, any electrolytics made pre-1991 should pretty much be thrown and replaced?
I Reject Your Reality And Substitute My Own - Adam Savage, Mythbuster |
| Page generated in 0.09693 seconds (81.24% PHP - 18.76% MySQL) with 9 queries |
