| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Can somebody tell me if the following 4 parts will work with each other?
http://www.parts-express.com/pe/show...number=093-252 http://www.parts-express.com/pe/show...number=093-240 http://www.parts-express.com/pe/show...number=092-034 http://www.parts-express.com/pe/show...number=092-036 Specifically, will the locking latches work between Neutrik/Switchcraft for both of those pairs?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#2 |
Hello 454Casull, Since they are all XLR style connectors, they should work fine with each other. XLR connectors are based upon a standard design. I forget who created, but Switchcraft is pretty much the standard bearer name. Neutrik is a newer company from Switzerland. Good connectors.
Peace, Dave |
#3 |
From A Brief History of the XLR Connector:
The IEC Standardized the dimensions of the XLR type connector but specified a very loose tolerance for the distance from the end of the female contact carrier to the body of the connector. Switchcraft brand connectors (and copies of them from Asia) are made to the shorter end of the allowed tolerance range, while Neutrik brand connectors (and copies of them from Asia) are made towards the long end of the allowed tolerance range. At times this results in connectors that will not latch when manufacturers don't properly follow the IEC Standard for their male connectors. se |
#4 |
Thanks for the info Steve. Scary that someone as ubiquitous as an XLR is still that non-standardized. Especially when it's considered a standard!
#5 |
Thanks.
Strange that I didn't automatically subscribe to this thread...
#6 |
I think the old Cannon corp. made these first......first time I saw them, in the 60s, they were called Cannon plugs...
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
| CDM 4 laser compatibility | Gasho | Digital Source | 5 | 3rd December 2010 04:48 PM |
| Can I use 4-pin Molex connector as speaker connector? | MikeHunt79 | Everything Else | 5 | 3rd June 2009 07:21 PM |
| Opamp compatibility | morfic | Solid State | 3 | 15th May 2009 09:54 PM |
| SoundEasy Compatibility With BassBox | Exhifi | Parts | 0 | 5th December 2007 08:38 PM |
| Philips DVD-A Compatibility | awsj | Digital Source | 1 | 4th May 2004 08:15 PM |
| Page generated in 0.07499 seconds (77.12% PHP - 22.88% MySQL) with 10 queries |
