| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
So I was thinking of putting together a DIY class D amplifier for a subwoofer with a few features that I imagine aren't typically found in your average amp. Probably something in the 1 to 2 kW range.
My primary interest is in the electronics/processing capabilities of the unit and not the plate portion. I was wondering if anyone knew of a supplier for buying just a standard base plate or would I be better off just buying the $99 dollar plate amp from PE and scrapping their amp section? If nobody sells these standard chassis, does anyone know of a company that would do prototyping for such a chassis at a reasonable price in the 10 to 20 unit volume? Thanks for any advice, Jason |
#2 |
Hi Jason
Before you actually buy some custom plates you should make up a prototype unit, as you need to define the number of pots, switches, heatsinks, etc. and their placement in your design. Using a pre configured plate may lead you to making compromises in layout. I suspect that the Class D amp may also need to be completely encased in a grounded shield to avoid RF problems. But, it sounds like a fun project, I hope you keep us up to date with your progress. Good luck!
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| WANTED: Subwoofer Plate Amplifier (500W RMS / 4 Ohms) | ViperZ | Swap Meet | 1 | 1st February 2010 02:36 AM |
| FS : 500w Subwoofer plate amplifier Keiga KGND5250 | smallangryboy | Swap Meet | 4 | 3rd April 2009 04:56 PM |
| Bargain Foster WF-100K subwoofer plate amplifier | sreten | Subwoofers | 0 | 24th March 2009 02:22 PM |
| Plate supplier for subwoofer amp | smallangryboy | Subwoofers | 0 | 1st June 2006 01:35 PM |
| Page generated in 0.07714 seconds (75.42% PHP - 24.58% MySQL) with 10 queries |
