| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello
For an audio controller project I am working on, I need a pot similar to this http://search.digikey.com/scripts/Dk...3I9503&x=0&y=0 This is a linear top shaft pot, with center detent - however this one lacks a builtin button allowing me to click it (similar to various rotary encoders) Does such a thing even exist? Thanks |
#2 |
"built in button allowing me to click it"? Do you mean that the pot has some kind of switch built into/onto it that is activated by pushing in the shaft?
If so, I remember certain products that had push-on, push-off switches attached to the rear. they were certainly purpose-built special pots which I have never seen advertised separately in any catalogs. If you need something like that I'd suggest contacting pot manufacturers directly, but expect the cost to probably be prohibitive - unless you plan to order a zillion of them. Charles |
#3 |
Hey, thanks for the reply.
What I meant is indeed a pot that has a built in momentary switch. I estimate I need around 50 of those so special manufacturing is not an option. Although as the project progresses I am realizing going with rotary encoders may be better for me - and finding those with a momentary switch is easy |
#4 |
Makezine to the rescue...
http://blog.makezine.com/archive/200...ntiometer.html It was posted some day ago |
#5 |
Yeah, I've actually seen this while googling for such a part..
Too much work for me I'm afraid ![]() It seems anyway the whole thing is getting way too expensive so I'm reconsidering my next steps.. |
| Where to get pot shaft extension? | Dustin Haug | Parts | 27 | 16th August 2011 01:47 AM |
| PS Audio Linear Control Center and Phono III | tomman888 | Solid State | 2 | 16th May 2009 09:21 PM |
| Inexpensive centre detent pots? | tcpip | Parts | 7 | 10th February 2006 07:42 PM |
| Detent pots | maylar | Parts | 11 | 19th March 2004 06:23 AM |
| Center to Center of Drivers 29" apart in proposed config - Problems?? | Ken L | Multi-Way | 14 | 3rd November 2003 12:49 PM |
| Page generated in 0.08452 seconds (70.52% PHP - 29.48% MySQL) with 10 queries |
