diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Power Meter (http://www.diyaudio.com/forums/parts/14944-power-meter.html)
PaulHilgeman 9th May 2003 02:38 PM
Power Meter
Has anyone looked at the power meter over at http://www.snippets.org/filters/wattmeter.htm ?
It looks interesting, and may be somewhat useful for testing stuff.
Thanks,
Paul
elizard 9th May 2003 02:48 PM
well looks simple enough to implement
for $5 you can get the chip from digikey (canadian that is!) and another $5 for led's ..
so $10 all in all to make it .. maybe i'll try it too! ;)
although i would love to find out if it works or not as well
gammelmalle 9th May 2003 07:29 PM
Testing ... what stuff? Seems good for RMS wattage but if not true RMS? I dont think it will be good for testing you wall outlet (how much your computer consumes) except for things with cos fi of 1 (that is resistive)
Please correct me if Im wrong!
But Ive used this IC for some of my projects and its OK.
björn
cocolino 9th May 2003 07:44 PM
Check this thread for info about (True) Audio-Power Meters:
http://www.diyvideo.com/forums/showt...&threadid=8723
JOE DIRT® 9th May 2003 07:53 PM
I have been using the LM 3914/15/16 for years.....it has a dot or bar functionthe 3915 is a log type and can fairly accuratenational has a great application guide on their website for different applications
Cheers!!The DIRT®
gammelmalle 9th May 2003 07:57 PM
DANKE
Thanks for the thread. I sure will read it
(Danke fur das ??? drath ? Ich will dass vierklish lesen) ????
björn
joensd 9th May 2003 08:05 PM
Hey Christoph,
I´ve just read you got this Elektor article about a wattmeter.
Would you mind sending it over?
I got a few Elektor articles as well so we could swap around.
TIA
Cheers
Jens
cocolino 9th May 2003 08:50 PM
Hi Björn,
you're welcome!
lessons in German;) :
Danke für das (den) ??? (don`t know an equivalent in German either... :cannotbe: ) . Ich werde das wirklich lesen.
Hey Christoph,
Jens,
no problem, just send me Your email adress.
As I have sent it to another member already it`s ready for "emailing".
The scans are rather big (even already downscaled in resolution) - can You receive 4MB without problems (but could send it in parts also)?
Copyright ©1999-2017 diyAudio
