Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th August 2009, 10:10 PM   #1
gychang is offline gychang  United States
Default different ohm volume/potentiometer?
what is the difference between various resistence vol/pot?
I usually use 50Ohm Alps but considering trying out the 100Ohm Radioshack model for my modded t-amp?,
thanks,
gychang
Old 12th August 2009, 11:30 PM   #2
Minion is offline Minion  Canada
I would suggest a 10k -50k pot .... a 500k will probably load the input too much and be noisier .....
Old 13th August 2009, 12:41 AM   #3
should have added K after ohms on the initial post. Will the 100K pot be reasonable?
gychang
Old 13th August 2009, 02:09 AM   #4
Geek's Avatar
50 to 100K will likely be unnoticeable.
Cheers!
Noble volume potentiometer Skorpio Solid State 0 9th January 2008 06:47 PM
NAD C370 Volume Potentiometer fail somelvis Solid State 4 15th July 2007 09:47 PM
Stereo volume Potentiometer hotscot Chip Amps 4 21st January 2007 07:12 AM
Volume Control (potentiometer) SergeDufour Parts 1 6th December 2006 09:56 PM
Volume potentiometer Morello Solid State 8 16th October 2002 02:29 AM
Page generated in 0.06818 seconds (74.58% PHP - 25.42% MySQL) with 10 queries
