Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th August 2009, 07:16 PM   #1
Default PNP NPN Complimentary Transistors
Hi - I'm repairing my old Sony F110 amp at the moment (see the end of this thread) and have discovered it's the output transistors causing the fuse blow.
After some searching (and help from Sinistersoulz) for replacement transistors 2SA1670 and 2SC4385, I've discovered the 4385's are near on impossible to source (unless I fancy paying a fair amount of postage from the States).
Cricklewood Electronics have recommended replacing the transistors with a different complimentary pair - 2SC4388 and 2SA1673. Having had a butchers at the datasheets they seem comparable to the original transistors, although I'm a bit reluctant to bung 'em in until I've had a bit more confirmation as I'd rather not fry anything else in my beloved amp!
What do you think? And ta in advance!
Old 12th August 2009, 07:21 PM   #2
Did it Himself
richie00boy's Avatar
Replace the drivers as well or you will probably end up doing it all over again.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 20th August 2009, 06:23 AM   #3
h_a is offline h_a  Europe
h_a's Avatar
I just had a short look at the datasheets and the Sanken 2SC4388 seems a good replacement to me. Similar fT and available in the same hfe-groups. Higher Voltage ratings may indicate higher capacitances as well, but that's most certainly not much of an issue.
Just be sure to check the hfe-group (O,P or Y) on the original (destroyed) parts and order the replacments from the same group. If in doubt go for the Y parts with highest hfe.
I would replace drivers as well to be sure (or at least test them) as richie already recommended.
Have fun, Hannes
MOSFET Quasi Complimentary ??? IIR Solid State 14 24th May 2009 05:31 PM
Complimentary power transistors in chip amp roshan101 Solid State 20 8th September 2004 01:10 AM
Complimentary-symmetry SUSY? vossie Pass Labs 19 16th February 2004 06:01 AM
complimentary pair Randy Knutson Parts 5 31st March 2003 11:55 PM
Page generated in 0.07094 seconds (71.91% PHP - 28.09% MySQL) with 10 queries
