I found these (Panasonic FC 2200uF/50v) "by-polarized" on eBay $16/10 incl shipping, compare to $2.60 each at digikey. No one is counterfeiting these things are they?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250472667349&ssPageName=STRK:MEWNX:IT
They certainly don't look like bipolar capacitors.
I wouldn't bother since some low ESR 2200uF, 50v capacitors are only $1.49 each at Mouser, or $1.25 each in quantities of 25 or more.
http://mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMsCnlYck6hSqJwQijas1Gw%2brDR/8ujO6b0=
might be a 'lost in translation' sort of thing ...
after all -
http://myworld.ebay.com/lovelyleila2008/
Item location:
‰·�B, Ÿ´�]�È, China
温州, 浙江省, China
115
after all -
Item location:
‰·�B, Ÿ´�]�È, China
温州, 浙江省, China
115
AndrewT said:Hi,
if they do not know what product they are offering, then why should you "take their word for it"?
Ebay seller from China, what do I have to worry about?
Just wanted to report that I received my caps from lovelyleila2008 ebay vendor and they appear fine. Took 2 weeks. I've tested for esr, consistent .02 ohm, the weight is about right, so is the cap and bung. The color is a bit off, the FCs are typically a dark blue, these are black like some FMs I have. Included was the 50 count bag that Panasonic ships these in. My only issue is that they were packed in an envelope and are a little bit scuffed from rubbing other caps, but not too bad. A real bargain if you want FCs.
I buy a lot of Panasonic FC from digikey and they're all dark blue in color, so no reason for them to be black, if in doub you could ask the manufacturer.
Anyway it's dirt cheap usd1.58/pc plus free shipping
after all -
Item location:
‰·�B, Ÿ´�]�È, China
温州, 浙江省, China
115
That particular place in China has been notorious for counterfaiting anything. Will never buy anything from there.
Just wanted to report that I received my caps from lovelyleila2008 ebay vendor and they appear fine. Took 2 weeks. I've tested for esr, consistent .02 ohm, the weight is about right, so is the cap and bung. [...]
If you want to know what value your caps are, slap a 1K resistor in parallel with them, charge them up to 10 volts, then remove the voltage and measure how long it takes the capacitor charge to drop to 3.7 volts. Multiply that by 1000 and there are your microfarads.
If that's too fast, use a 10K resistor and multiply the time by 100. Math available on request.
Whadya make of these?
I can't find it in the Elna catalog. Do they have color schemes for special projects or OEM's. Is this a discontinued model? Any ideas? Thanking all in advance.
http://www.hllye.cn/html/fm_transmitter_1_137.html?currency=USD&products_id=137
According to this panasonic link, different colors are a sign of possible counterfeit product. I'll see if I can get in touch with that panasonic group and see if they are interested in a sample. These look quite good, though, maybe even better than original! Tubeshunter on eBay also appears to have the exact same product, black 2200uF/50v with 32YV code on them.
http://www.panasonic.com/industrial/components/utilities/alerts-content.htm
- Design & Build
- Parts
- Panasonic FC Dirt Cheap
