diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Nichicon KG Series as Filter Caps (http://www.diyaudio.com/forums/parts/148191-nichicon-kg-series-filter-caps.html)
DreadPirate 28th July 2009 01:10 PM
Would these be suitable for use as the main filter caps on a power supply for the NAP140 clone, or would something like the Mallory CGS or Cornell DCMC series (computer grade) be more suitable?
analog_sa 28th July 2009 01:22 PM
Not only suitable; they will likely sound better.
bobbyrae 29th June 2010 10:34 AM
I have the same question. It seems to me that filter caps are NOT dealing with audio at all, and therefore you want caps that will filter out the ripple best. Isn't money spent on the Nichicon KG series just a waste? I look at my integrated amp, where they used Nichicon throughout, but used United Chemi-con for the filter caps. And I ran across a website where the operator spends his time restoring Marantz recievers - he says he uses United Chemi-con for the filter caps, too.
So...?
marce 29th June 2010 11:40 AM
I've got to ask also how can filter caps alter the sound?
wintermute 2nd July 2010 11:02 AM
The powersupply caps provide the (hopefully) stable voltage that feeds the amp, it is this voltage that gets modulated to make the final sound. If you think about it that way then isn't it logical that there is the potential for these caps to affect the sound?
Ever tried putting a scope on the powersupply and running a sine wave through the amp at close to clipping? you might be surprised (or horrified) at the result ;)
Nichicon KG's are regarded as many as being excellent power supply caps. I've bought some for my amp but haven't actually put them in yet, and from what I've looked at they aren't really that expensive!
Tony.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
