| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Is there any way to assemble audio plugs without soldering?
Example: 18 gauge zip cord to a banana plug. Some sort of twist on assembly is preferred but I haven't seen such at Parts Express or other. Barring anything twist on, can the parts experts here give a good source for an assembly tutorial for making audio connects? |
#2 |
You should defenetly learn to solder,
It's not that hard, you only need the proper tool. I've started with a cheap RadioShack 15 watt iron and learnt from sctrach... (bad idea) If you want to make it easier, get a decent ~$25 (and more) soldering iron and practice on old PCI/ISA board. Soldering a plug is quite easy compare to PCB. Have fun here some articles from the Make magazine which should help you : http://blog.makezine.com/archive/200...to_solder.html (kids can do it !) http://blog.makezine.com/archive/200...n_make_te.html (a nice video on how to solder) |
#3 |
Speakerholic
Do you mean like this?
http://www.parts-express.com/pe/show...TOKEN=48868246 You can get a dual version from Q components in Canada. |
#4 |
some Banana plugs have a grub screw to grip the cable end in the bored receptacle.
regards Andrew T. |
#5 | |
My problem with these things started back 40 years ago. I tried to manually get an RCA phono plug made with the POS lead down the center and and ground lead on the frame. That's primitive. But that's where I gave up on it. I also once soldered a standard phono plug but those things are as big as my index finger. Trying to flow solder down the center of an RCA plug was too daunting. Everything I've seen since looks like that and puts me off. So I've just been direct connecting with female ends for the spade lugs on drivers. I can manage to solder those and put a heat shrunk sleeve on for neatness. So if those PE ones can be wrapped with the wire and screwed tight, that is a solution. |
#6 |
You owe it to yourself to get back on that horse and ride.
I had lots of bad soldering and building experiences as a kid as I had bad equipment, no guidance and on top of that was kind of careless. Getting over this opened up lots of possibilities for me. With regard to your experiences, I will say that soldering those RCA tips can be frustrating, and will be very difficult if you don't have enough wattage in your iron. So it's not as simple as a task as it might appear. --Buckapound |
#7 |
Buckapound,
Your childhood experience sounds like mine. Some peeps can build Heathkits, for others they would never work. I have some fairly fine solder, a 30 watt iron and even some of that wicking stuff plus a sponge and some forceps for the tricky holds. But I've never been taught electronics or how to read schematics. I even bought a textbook once but didn't get very far. My regular forum in DIY audio is the single driver loudspeaker section. What is the standard banana plug form and how is it put together? This seems needlessly obscure. But thanks for answering. I think there are always some in the hobby that go through this. |
| Quick Question - Audio Note M1 or AR SP-6? | john65b | Tubes / Valves | 8 | 1st March 2009 03:03 PM |
| Gold plated female quick connect spade terminals (.110", .187") | dholcombe | Parts | 1 | 29th January 2008 11:16 PM |
| Quick connect binding posts? | CarlyBoy | Multi-Way | 5 | 27th December 2007 10:28 PM |
| > Audio <> music <> quick <> synergy <> angst>? | rick57 | Everything Else | 0 | 4th May 2007 04:03 PM |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 04:20 PM |
| Page generated in 0.08636 seconds (85.84% PHP - 14.16% MySQL) with 10 queries |
