Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th July 2009, 10:40 PM   #1
anm is offline anm  India
Default external HDD player, with touchscreen and digital out
For my home stereo system, I want a player like iPod touch, but with digital out and expandable memory - by attaching an external 500GB type of hard disk.
Should be able to play at least WAV format, but better if flac etc.
I think squeezebox touch can be one such product - but it is not beyond rumor as of now.
Can you guys suggest something? Or maybe I can do some DIY to mod the ipod touch, or assemble some other kit?
One good alternative I see is http://cgi.ebay.co.uk/Car-DVD-Stereo...03154001r25178
However, not sure about the quality. I think it should not be too bad if it can read from hard disk and send music over digital output?
I know building a computer is a very flexible and great idea, but I just don't want to do it.
Old 24th July 2009, 11:31 PM   #2
star882 is offline star882  United States
star882's Avatar
There's a USB HD media player by Western Digital for about $100.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 25th July 2009, 04:04 AM   #3
thanks Star. I forgot to mention, it is a music only setup - so no monitor/ TV present. I need something that has a display of its own - that's why touchscreen (or may be a remote but definitely no keyboard + mouse.
Also I read somewhere that WDTV resamples music at 48khz - something similar to what kmixer does in windoze.
regards
Old 25th July 2009, 05:16 AM   #4
sivan_and's Avatar
Send a message via Yahoo to sivan_and
http://www.wdc.com/en/products/products.asp?driveid=572
SivanandBalan
Old 25th July 2009, 07:30 AM   #5
thanks - but I don't want this. It does not have any built in display. Also sound quality is doubtful as it resamples audio at 48khz
regards
Old 26th July 2009, 08:36 PM   #6
star882's Avatar
Build your own with a small PC running Linux.
Old 27th July 2009, 07:26 AM   #7
building comp is a big exercise, specially selecting the "best" components. 100s of hours spent in reading reviews of individual elements. What sound card to use? Will the best sound card have the best drivers available for linux, etc.
Then, it too would need a separate monitor in order to search/ select/ play. Then there are issues of unclean shutdown etc. A very real threat in the place I live, several times a day there are power cuts.
regards
Old 27th July 2009, 02:34 PM   #8
star882's Avatar
Just about any common sound card works on Linux. Or just get a mini ITX board that has a HD capable sound card with digital output onboard.
You can simply mount everything read only except in service mode. Many embedded network devices out there do just that and the only way to turn those off is to unplug them.
Old 27th July 2009, 08:35 PM   #9
ok - so you are saying I should use an external DAC?
Any stereo sound card recommended for analog out that works with linux - like asus xonar?
What about the disk with the song - can that get corrupted if unplugged?
I guess that too should be mounted read only? But what about saving settings/ creating playlists etc?
regards
Old 27th July 2009, 08:50 PM   #10
star882's Avatar
Use a pure digital amplifier. Keep it digital until the very last moment. Converting it to analog at high power levels gives a higher SNR.
You can temporarily remount the disk as RW to save settings, then revert to read only.
adding a digital coax to a dmp35 to link with an external dac littlechicken Digital Line Level 0 17th May 2009 11:31 PM
Is this the best Double-Din dvd player with touchscreen out there? kcmoguy26 Car Audio 2 16th December 2008 01:05 AM
external pitch control mod for cd player amc32 Car Audio 4 19th November 2008 11:48 AM
External SC - priority on digital out and line ine. Vikash Digital Source 0 1st July 2005 01:01 PM
Putting an external DAC inside a dvd/cd player Vinnie R. Digital Source 3 14th July 2003 05:31 PM
Page generated in 0.23984 seconds (38.22% PHP - 61.78% MySQL) with 10 queries
