| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
Thanks.
I think I am ready to walk the path to setup my own comp, for music only. Need help with 1. which mother board/ processor - I think for music purpose I do not need fancy mobo with hdmi etc. Will a dual core be better than single? 2. sound card - asus xonar essence stx. Are linux drivers for it working? 3. OS/distro - which distro to use, and trimming it down 4. power supply/ casing etc 5. hdd - internal or external? |
#12 |
Just get any cheap motherboard that has 24 bit S/PDIF output. All you're using the sound card for is a special high speed serial port. And you don't need very much CPU at all. One of those mini-ITX boards will work fine.
If you're using a mini-ITX board, build your own power supply using a cheap laptop wall wart and some buck converters. With the low power usage, a normal ATX supply might not even start up. (That problem actually happened to a friend of mine.) Here's a good one to start with: http://www.frys.com/product/5845773?...H:MAIN_RSLT_PG You can even run a small digital amplifier from it at the same time. Use a CF card for the firmware. I'm not sure about the software, but something like Linux from Scratch or the x86 port of OpenWRT might be the best to start with. Mount everything read only and start up a media browser by default.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#13 |
but I want to use the asus sound card - instead of an outboard dac!
Will it fit into a mini itx board? Can you please suggest a mini itx board? I live in India and 90% probability is that I will buy it across the counter, where I would have to explain the last detail to get something. regards |
#14 |
The digital output does not use the DAC. It is merely a very special high speed serial port.
But you can use a separate sound card if you wanted to.
#15 |
no I meant I do not have digital input on my amp. So if I use digital out of the comp, I would need to feed it into a DAC that I would need to purchase separately. My stereo HK 6550 amp takes only analog inputs.
Are you suggesting atom kit? regards |
#16 | |
#17 |
thanks Paul. I have recently purchased the apple tv 160gb model, and tested the ipod remote with it. It works really well that way. Waiting for an ipod touch to come my way.
Limitations - no usb or flac without playing with the fw. Not sure if remote app will work after I try some of the hacks. |
| adding a digital coax to a dmp35 to link with an external dac | littlechicken | Digital Line Level | 0 | 17th May 2009 11:31 PM |
| Is this the best Double-Din dvd player with touchscreen out there? | kcmoguy26 | Car Audio | 2 | 16th December 2008 01:05 AM |
| external pitch control mod for cd player | amc32 | Car Audio | 4 | 19th November 2008 11:48 AM |
| External SC - priority on digital out and line ine. | Vikash | Digital Source | 0 | 1st July 2005 01:01 PM |
| Putting an external DAC inside a dvd/cd player | Vinnie R. | Digital Source | 3 | 14th July 2003 05:31 PM |
| Page generated in 0.11337 seconds (76.12% PHP - 23.88% MySQL) with 10 queries |
