Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th July 2009, 07:38 PM   #11
Drill a small hole through the flange, loop the wire through and solder. You get a good mechanical and solder connection.
Old 24th July 2009, 10:26 PM   #12
I think I'll give it a try. Cardas should incorporate that into their design.
Old 25th July 2009, 11:34 AM   #13
SamL is offline SamL  New Zealand
What type of solder tip have you got on your soldering iron?
A wide chisel tip will be able to transfer heat a lot faster than a pencil type.
FS: Cardas female RCA (GRFA S Thick) Monkey King Swap Meet 5 27th January 2009 11:13 AM
Soldering Cardas Female RCA's? dantwomey Everything Else 2 16th December 2007 04:31 AM
help soldering ground wire to a Cardas female RCA chassis socket jarthel Parts 4 6th March 2007 02:23 PM
Looking for Source of 5 Pin DIN Female Connector- similar to Cardas for tonearm dtm1962 Analogue Source 2 2nd December 2006 12:17 PM
Soldering to Cardas female RCA connector 41 Parts 4 25th July 2005 04:46 AM
Page generated in 0.07141 seconds (66.37% PHP - 33.63% MySQL) with 10 queries
