Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd July 2009, 04:47 PM   #1
DAKOS is offline DAKOS  Canada
Question 90A740 data sheet please
hi,
does any one has a data sheet please for this IC ? or at least what kind of component is it? i suspect it may be a eeprom but not sure...
thank you!!
Old 23rd July 2009, 12:13 AM   #2
DCPreamp's Avatar
Question Need more info
Can you post a picture and details? What's it from, package, pin count, etc?
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so."
Old 23rd July 2009, 12:22 AM   #3
it is a standard IC package..8 pins (4 on each side)..
i did a google search for the part but all i can found were some sellers ..no data sheet available...
thanks again!
Old 23rd July 2009, 04:06 AM   #4
DCPreamp's Avatar
Does it have a date code?
Does it have an additional prefix or suffix?
What is it next to? A microcontroller, an encoder, an LED, a power transistor, a modem?
What does the board do? Is it an amplifier board? Is it a PC motherboard? Is it from a TV?
It's much easier to reverse-engineer a board and ID components with a picture, thorough board description, knowing the board function, nearby components, what pins of the IC are Vcc and ground, etc.
I'd love to help but still need more data.
Old 23rd July 2009, 05:11 PM   #5
..the pcb is actually a car ECU...there are only 2 ICs on it and a few other passive components... the other IC is a big one so 100% that's the "processor" and my guess is that the small IC is the memory where all parameters are updated ... since no other IC around i'm more convinced that this should be the memory chip...
DSD 1751 data sheet fmak Digital Source 0 25th June 2008 11:51 AM
looking for old data sheet unclejed613 Parts 3 13th May 2007 06:35 PM
op amp/dac data sheet help Smiffy Parts 11 13th December 2004 08:14 PM
data sheet KCC Parts 5 6th January 2004 09:03 PM
Page generated in 0.08187 seconds (71.43% PHP - 28.57% MySQL) with 10 queries
