Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th May 2003, 05:48 PM   #1
Matttcattt's Avatar
Default source of aluminium in UK
does anyone know where i can buy small pieces, about 30cm by 30cm (1' by 1') of sheet aluminium about 6mm (1/4") in thickness? preferably in bristol.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 5th May 2003, 07:56 PM   #2
Tim F is offline Tim F  England
I'm not trying to be smart but have you looked in yellow pages under 'Aluminium'. You should find some ally fabricators one of who I'm sure could offer you some off-cuts. If you can be slightly flexible on thickness i.e. 5mm-8mm you should have a good chance. Also depending on your intended use some of them may well carry 'chequer plate' (used for stair treads & lorry steps & floors etc.
Hope this helps.
Old 5th May 2003, 08:09 PM   #3
fezz is offline fezz  United Kingdom
looking under aluminum will not revil much, best idea is to look under steal fabricators - they usally carry aluminum
failting that i belive www.rswww.com may carry aluminum around the same size... it should be under mechanical - non ferious stock
Old 5th May 2003, 08:25 PM   #4
Fezz
I don't know if it varies from area to area but my Manchester yellow pages lists 'Aluminium Fabricator's' + 'Aluminium Welders' & 'Aluminium Stockholders' although I suspect that stockholders will charge a fortune for small quantities. If I remember rightly their is a fair bit of aerospace work in Bristol area & so probably quite a number of companies messing around with Aluminium.
Old 5th May 2003, 10:46 PM   #5
phill77 is offline phill77  United Kingdom
You could also try mail order metals .
Old 5th May 2003, 11:02 PM   #6
pinkmouse's Avatar
Folkstone Engineering are a good company, the're not set up to do huge amounts of sheet metals yet, but the're worth a call to see what they have lying around. They also do other stuff like brass, copper and bronze.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 6th May 2003, 12:29 PM   #7
TJ is offline TJ
Hi, did u know any workshop do prototype chassis ?
thank
Old 6th May 2003, 02:13 PM   #8
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Match the grade to the purpose...
I got some 300mm x 500mm x 6mm from RS components.
The problem was that it is a very soft grade. Normal twist drills sieze if not cleaned after each hole.
I had wanted to blind tap into it for 3mm screws (I have done that successfully for years on the normal 50mm x 6mm bar), but this stuff just has no strength.
My 2p...
Old 7th May 2003, 07:05 AM   #9
Matttcattt's Avatar
im going to use it for a heatsink. i only need one piece. i can be flexible, 3-10mm is ok ill have a look in the yellow pages. thanks for the help.
Old 7th May 2003, 08:19 AM   #10
SuppersReady's Avatar
Hi TJ,
You should be able to get an engineering/machining workshop to produce a prototype chassis if you produce some drawings for them. Be prepared to pay for good work though. That's the route I took.
Paul
aluminium box space-cake Parts 1 19th September 2006 12:34 PM
Large aluminium knobs, a source? homer09 Swap Meet 12 17th February 2005 04:58 AM
Inox or Aluminium ElectroPower Chip Amps 2 5th December 2004 12:32 AM
Aluminium Supplier Delboy Parts 0 22nd May 2003 05:24 PM
Brushed aluminium Vivek Everything Else 4 18th July 2002 06:20 PM
Page generated in 0.10578 seconds (82.91% PHP - 17.09% MySQL) with 10 queries
