| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
When wiring up a +/0/- DC supply, what color wiring do you use? I suppose red for + is pretty universal, but what about 0 and -? Black and white respectively? I don't think green is a good idea because it might lead some to believe that there is earth.
Also, what other conventions do you follow or think others should follow?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#2 |
I use red/black/blue for +/0/- respectively. This seems to be a relatively common scheme.
https://mrevil.asvachin.eu/ |
#3 |
What else can blue be used for? I don't want to keep too much wire in stock.
#4 |
I use Green for ground, and Black or Blue for negative.
Other conventions to live by: 1) If it looks good, eat it. 2) What would happen if everyone did it? |
#5 |
It all depends on what circuit I'm working on. For my bench power supply, I use colors similar to those on PC power supplies - black for ground, yellow for 12v, red for 5v, orange for 3.3v, and green for another voltage.
One tip to avoid having to stock many different colors of wire is to stock many different colors of tape. Use the tape to make an identification color band on the ends of each wire. In a circuit where an exposed ground is not a problem, I have used red for the positive, black for the negative, and, of course, bare for the ground. At my university, one of the engineering labs (for ECEN 214, which was analog) used red for the positive, black for ground, brown for negative, and blue for another positive. Another one (for ECEN 248, which was digital) used red for one positive, black for ground, and brown for another positive. (I wonder if anyone managed to blow something up by getting confused about the colors... The electrical engineering department should adopt rules about what colors to use on bench power supplies.)
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#6 |
OK, if anything goes, what color should I get next? Currently I have red, black, and some orange.
#7 |
Blue.
/U. |
#8 |
Blue is the color for neutral in mains, so better NOT use it.
#9 | |
#10 |
hi all,
the mains wiring colours are not the same in different parts of the world, including the 3 phase. i use red green black for + 0 -, very old UK convention that i have just stuck with.
regards bob |
| Naming conventions of Sony drives | Floric | Digital Source | 0 | 20th January 2007 07:43 PM |
| Naming conventions | lndm | Tubes / Valves | 2 | 9th December 2006 04:55 AM |
| Page generated in 0.09006 seconds (81.69% PHP - 18.31% MySQL) with 10 queries |
