Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th July 2009, 01:32 PM   #41
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Originally posted by Stuey
Guys, regarding your general comments about blade depth and general saw use, I have to stress here that I'm no novice in using a circular saw.
Stu
That was at least not my point anyway, but there's a lot of people reading these threads, and I have been more than amazed and closed to horrified sometimes of some the suggestions and solutions that creep up around here....
Some are really and some are really , while every now and then, infrequently often, some are really - even for old geezers....
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 17th July 2009, 02:40 PM   #42
Speakerholic
Cal Weldon's Avatar
Originally posted by MJL21193
As odd as it seems, radial arm saws are used the way sandyhooker says - pulled toward your through the work. This applies to aluminum cut on a radial arm saw also
John, radial arm saws are used both push and pull. If you are attempting to pull, you'd best know what you are doing, use an anti-climb blade and make sure your insurance is up to date. This is not for the uninitiated. If you are using as a push, there are virtually no problems if you clamp the work down.
[i](Though I would NEVER use this saw to cut aluminum). Using it the other way (pushing it through the work) is dangerous... [/B]
Aluminum is fine on a radial saw but I would never, repeat never try it in pull mode.
John, I have spent a number of years in aluminum fabrication and I am having trouble reading what you are typing.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 17th July 2009, 02:53 PM   #43
Speakerholic
Cal Weldon's Avatar
Like any dangerous tool, the radial arm saw has a some learning attached - the blade needs to be the correct type (low angle for less agressive cutting) and shouldn't be used by someone who isn't familiar with it's operation.
If done correctly, cutting aluminum sheet with a circular saw when the sheet is clamped down and using a sharp carbide METAL cutting blade in the saw is more safe than using a tablesaw.
I agree with the first point.
I think the second point is up to the operator. A table saw is not that dangerous but I must admit I still a lot of persons standing behind the stock rather than beside, not using a feeder stick, no gloves, no ear protection, no goggles and removing the guard.
Old 17th July 2009, 05:33 PM   #44
MJL21193's Avatar
Cal, A quick search of radial arm saw safety on google will confirm what I'm saying. I learned it from my father (and also in trade school) long ago, have been using these saws for nearly 30 years.
To crosscut on a radial arm saw you pull the blade through the work - this is not an option. To push through runs the risk of the blade grabbing the work and forcing it up. Your advice on this matter is not only wrong, it's dangerous. Clamping the workpiece down to attempt a push through cut is ridiculous.
Maybe a quick sketchup drawing will clarify what I'm saying about using the hand held circular saw to cut sheet aluminum. Below is the drawing - on the bottom is the scrap plywood or MDF, above that ( smaller) is the aluminum sheet and on top is the strip of plywood that will act as the fence or guide for the saw. This is clamped down on both ends. Clear?
Old 17th July 2009, 05:55 PM   #45
chrisb is offline chrisb  Canada
If I may posit a question - wasn't the source for the aluminum plate as offcuts from commercial production? If so, wouldn't that fabrication shop have a power shear that could safely cut the material in less time than it takes to read this post?
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 17th July 2009, 06:26 PM   #46
paulb is offline paulb  Canada
Originally posted by Minion
The metal shop by my house will sell me and cut to size a 19in x4in x1/16in Aluminum plate for $6 ...... it"s probably cheaper if you allreay have the aluminum plate .....
Where's that? I get out there occasionally and could use a couple of panels like that.
Old 18th July 2009, 02:39 AM   #47
Stuey is offline Stuey  Australia
That's exactly what I meant way back in my first post, only the 2 guides were to be bricklayer's profiles, which are 1" square steel tubing. This is what I do with wood for speakers and it works very accurately if set up properly.
Chrisb, two things to note - the offcuts were from a CNC water jet cutting shop and that's all they do. Yes, they could do it, but it's 10km away and they need to fit these small jobs in between their larger programmed ones. I don't like to interrupt them as they kindly give me aluminium offcuts for almost nothing. The other thing is that, as mentioned above, this thread was more for the long term, so I could use the method on a number of projects. So while I could easily go to a metal shop a couple of kays away, I'd rather get a setup I could use at home.
Cheers
Stuey
Old 29th July 2009, 12:08 PM   #48
An update; the local sheet metal shop cut them with their guillotine in literally two minutes. Worth it for sure...minimal filing required as well.
Stuey
Old 29th July 2009, 10:00 PM   #49
Magura is offline Magura  Denmark
Magura's Avatar
Stuey
And don't forget, you still got 9 fingers
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 31st July 2009, 09:39 AM   #50
No, I'm all thumbs.
Cutting holes in aluminium enclosures emperor Parts 4 22nd July 2007 07:45 AM
aluminium box space-cake Parts 1 19th September 2006 12:34 PM
WTB 2 aluminium knobs fireman Swap Meet 2 6th August 2004 07:50 PM
source of aluminium in UK Matttcattt Parts 9 7th May 2003 08:19 AM
The right tool for cutting aluminium??? Tazzy Everything Else 6 27th September 2002 05:48 PM
Page generated in 0.11366 seconds (81.39% PHP - 18.61% MySQL) with 11 queries
