| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Damaged transformer in transit, has an indentation where it hit a nearby circuit board, now has an 1/8" deep gap at that location, wires under it crushed. I know this is unsafe to operate. My guess is that the insulation has cracked and could fail. Also, if the wires have narrowed, could create a hot spot. What's the worse that could happen? This is a 1000VA beast.
#2 | |
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#3 | |
#4 |
I´m amazed!
A detail photo would be helpful to consider the damage. What I would try (not claiming to have the best idea) is to attach a mains connector, plug it into the socket and pull it out again immediately. If the primary winding is shorted, the mains fuse will trigger. If a secondary winding is shorted, you will hear the transformer "gnarl" with mains frequency. The sound will be quite distinct.
If no gnarling occurs, measure the secondary´s voltage(s). If they are o.k., connect a (dummy) load to it and observe. Worst case is that the winding(s) heat up, the insulation goes up in smoke and later the windings will start to melt. But that would take some time, much more than you´ll need to hear it gnarl and pull the plug. No need to say that you should not have the transformer lying on your bosom while trying that. Keep away from it some feet. |
#5 |
You asked for it, you got it. The first picture is the transformer, an 1100VA monster. It slammed against the circuit board which ended up crushing it to a depth of about 1/8". The xformer is made by JMP Electronics which supplied Aragon and on Monday I will find out if these might still be available. The next picture shows the rectifiers mounted on the board that got impacted. The pins are bent in the direction of the impact location. The last picture is the rectifiers from above. The leftmost one is the most displaced, it is closest to the impact location. A shame, but amazing how well built this thing is, it probably survived a freefall drop of about 5'. Thank you UPS.
#6 |
Closeup of the transformer.
#7 |
Closeup of rectifiers.
#8 |
My guess it's repairable. Remove transformer and carefully peel back insulation at the affected area. Inspect with a magnifying glass and remove any debris. Use 2 part epoxy to reinsulated damaged enamal coating. Test with a variac with no load first. UPS won't cover the damage?
#9 |
My first inclination is to just leave alone. It appears to be working fine, at least sound-wise, I've taken no measurements. The seller knows I have the right to send this baby back, but is not pressing the issue. UPS has probably already notified him they will not pay the claim for one reason or another, though they clearly dropped the unit, the impact damage is readily apparent. I've got a line on "Mike the Technician" at JMP Electronics who allegedly worked on supplying these transformers for Aragon back in the day. If I can get an exact replacement (who knows, maybe they were matched or something and its not possible) I may hit the seller up for it and a bit of additional restitution. What's amazing is how well built this thing is, it took some cosmetic damage on the faceplate, but given the fact that it was dropped in freefall for about 5' and still works is quite a feat.
#10 |
It looks worse than it is. Luckily it hit where the flying leads are attached more cushin'.
| Modulation transformer for a driver transformer? | ironradio | Tubes / Valves | 6 | 28th December 2008 05:05 PM |
| PowerAmper Tube Amp.Crushed | amc32 | Car Audio | 5 | 1st July 2008 08:30 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 10:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.10353 seconds (78.49% PHP - 21.51% MySQL) with 11 queries |
