Ok so I'm making a Amp6-Basic boombox (along with the rest of the world) and I've decided to use this: http://www.mini-box.com/picoUPS-100-12V-DC-micro-UPS-system-battery-backup-system to manage the power side of things (of course I'm using an AC/DC input in conjunction with an SLA battery).
Now I don't want to have an external power brick, so after pottering around the interwebs I found this: http://www.wellforces.co.nz/index.p...utput-Switching-Power-Supply/flypage.tpl.html and this: http://www.wellforces.co.nz/index.p...utput-Switching-Power-Supply/flypage.tpl.html which are small enough for me to fit into the electronics compartment.
Also, before anyone points this out: They're meant to be 15V. The picoUPS-100 needs 15-18V, so it can simultaneously charge the battery and provide power to the load. The Amp6-Basic won't be getting 15V.
So... questions:
(1) These two power supplies are the internal equivalents of a big, black power brick right? (Just not 100% sure on this... want know I'm buying the right thing.
(2) How much power do I need? The company has a selection from 5W-48W, I just happened to pick the 15 watt ones. BTW, the amp is driving two 25W Tang Bands.
(3) Which one should I get? There's essentially no difference except for the casing... though I suppose casing would be safer...
(4) Would there be any noise/buzz issues with these power supplies being in very close proximity to the Amp6-Basic? Looking in the specs there's some "ripple and noise" thing which for the cased was 150mV and the caseless 120mV, if that means anything.
Thanks muchly for any help.
So... questions:
