Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd July 2009, 11:41 AM   #21
col is offline col  Australia
col's Avatar
yes, Iv'e read the entire thread. I know that the volume control is IR, I'm obviously not requesting that as a feature, more the option to be able to trigger relays or something to turn off more than one piece of equipment. Usually, when I shut down my system I have to turn the amps off first and then all the signal processing stuff. Would be very cool to have a means to be able to hit one button and that sequence to take place.
cheers,
col.
http://www.minirig.org.au
Old 3rd July 2009, 12:15 PM   #22
Andreq is offline Andreq  Canada
I'll look into it.
I don't see why it would be possible to plug 2 or more "Relay module" on 1 µC IO.
If this particular IO control power, than every connected module would power on/off according to it.
Old 3rd July 2009, 10:37 PM   #23
col's Avatar
So I would just need to put a start up module (client) in each bit of equipment then program the server module to get the sequence right? That sounds great! At the moment turning on the HiFi is a bit like the start up sequence for the space shuttle
col.
Old 3rd July 2009, 11:02 PM   #24
Kinda,
but the "relay module" will only use 1 IO pin with 5v and gnd... if everything goes well, you should be able to plug 1,2 or 3 module on the same IO pin/5v & gnd connector and they will all work at the same time.
Old 3rd July 2009, 11:14 PM   #25
col's Avatar
here is a photo of the insides of my preamp.
http://pix.minirig.org.au/main.php?g2_itemId=1150
It's basically a bunch of modules from ESP. I'm using a ESP P05b power supply that has a unregulated AUX voltage of around 20v I could use that with a LM7805 to power it.
http://sound.westhost.com/project05b.htm
col.
Old 4th July 2009, 03:42 AM   #26
Upates :
I made a little (big) mistake on the volume control module!
After reading the data sheet a little bit more, I found that pin 11 (agnd) stand for Analog Ground, and not... address gnd.. which it why I tied it to gnd...
I've managed to isolate the problem on my already made pcb. I'll do some more testing using this board. I might need to add a "Wheatstone Bridge" (4 resistor x 2 channel).
Next time I'll take time to read everything -_-
Anyway I'll be able to save this little PCB.
I've attached the revised PCB
How to volume control for mini UcD180 project? tfboy Class D 7 29th April 2009 06:33 AM
Remote Volume Control + Extra board + Alps Motorized Pots jamesjung21 Swap Meet 12 23rd November 2006 09:03 PM
Aleph P 1.0 volume control board question? tomchaoda Pass Labs 31 21st July 2004 03:24 PM
Another APOX volume control project tiroth Solid State 17 30th March 2004 08:25 PM
Relay-based passive volume control project BrianGT Everything Else 110 1st March 2003 01:27 AM
Page generated in 0.08490 seconds (73.66% PHP - 26.34% MySQL) with 11 queries
