| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
While digging around the local surplus shops I picked up some rectagular stacked "film" caps. These have conductive metal end caps. There is a stiff lead on each end.
All three stores have these. They range from 0.1 ufd to 2 ufd. With voltage ratings up to 400v. Most are not branded, some are coated all over, and the 2 ufd 100v ones are coated on the conductive ends. These were picked up to bypass decoupling caps, but the larger ones look interesting for use as a coupling cap. Are these good quality parts for either decoupling or coupling in solid state gear? George |
#2 |
Hi George,
do You mean this ones? If so, I wouldn`t recommend for coupling in audio applications. IMO any cheap MKP type is better than those Siemens MKT`s. The only advantage they have is that they are small in size compared to other types. I cannot comment about decoupling.
Christoph STEAL the BEST - INVENT the REST |
#3 |
Thanks Christoph!
What is the dielectric of these? I bought them for bypassing some elctrolytics used for chip decoupling. The idea of using them for coupling was something I thought of after finding some 2 ufd ones. They look cheap, but I had hoped they might have good electrical properties. George |
#4 |
I think they would be fine for power supply decoupling...they look like a solid cap to me
#5 | ||
): PolyäthylenterephthalatThat`s what I found in the catalog from where I usually buy my parts. They are listed under MKT foil caps. Quote:
I have also some of this 2µF (to be exactly they are 2,2µF) but I don`t use them for coupling in audio. Maybe the overly small size and the dielectric (other types of MKT`s of same voltage rating and value are much bigger usually, not to speak from MKP`s....) have something to do with it - I really don`t know. I never measured one regarding dissipation factor.
| paralleling film caps with electrolytic caps | jarthel | Power Supplies | 386 | 23rd April 2013 09:09 PM |
| Siemens sikorel caps | rwagter | Parts | 21 | 31st July 2010 05:47 PM |
| attic clean up - Siemens 47nF KP film caps | cocolino | Swap Meet | 0 | 20th May 2006 08:41 PM |
| Siemens PP caps | Magura | Parts | 0 | 23rd April 2004 12:44 AM |
| FILM Caps to assist Big ELYT Caps | gromanswe | Parts | 0 | 9th July 2002 08:16 AM |
