Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th June 2009, 11:27 PM   #1
spacies is offline spacies  New Zealand
Default Mental block! Simple crossover help.
I had a kock on the head a while back (car) and my remembery is shot to bits
I want to wire a 20ohm resistor and a 2mf cap in parallel as a simple filter for tweeter and woofer.
Can someone please help with a simple sketch.
Many thanks
Old 27th June 2009, 11:50 PM   #2
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
spacies,
Is this what you're looking for?
| ____R____|
Mike
Marantz PM8003 amp, HRT Music Streamer II DAC, Squeezebox Touch, DIY Krystals
Old 28th June 2009, 12:08 AM   #3
tinitus is offline tinitus  Europe
Is it a piezo tweeter ?
Old 28th June 2009, 12:09 AM   #4
Thanks,
It is for a dual concentric driver ie one terminal for compression driver and another connection for the woofer.
Thanks again
Old 28th June 2009, 02:53 AM   #5
Originally posted by mikje
spacies,
| ____R____|
Mike
Hi Mike,
I am not sure sorry.
Where do I connect to the tweeter and the woofer?
Thankls
Old 28th June 2009, 03:00 AM   #6
mikje's Avatar
Spacies,
I believe one would have to go in-line with each speaker.
Mike
Old 28th June 2009, 03:09 AM   #7
Thanks,
It is for these:
So I do I wire them together and put it in front of the tweeter input or the woofer input?
Old 28th June 2009, 03:12 AM   #8
mikje's Avatar
spacies,
Sorry... I'm not familiar with those. Are they co-axials? What's the function of the filter you mentioned?
Mike
Old 28th June 2009, 03:16 AM   #9
Yes they are coaxial.
The function is to bring down the shouting from the compression driver. I was told the 20ohm resistor and 2mf cap in parallel is what I require.
I have the parts :-)
Old 28th June 2009, 04:49 AM   #10
mikje's Avatar
spacies,
I would run it in-line with just the compression driver. I don't think it matters what terminal you run it in-line with, as long as it's the same on both speakers.
Hopefully that makes sense. Let me know how it works.
Mike
Simple fixed crossover soundNERD Chip Amps 2 28th May 2004 12:44 PM
simple crossover da_madaxeman Multi-Way 58 29th November 2003 01:58 PM
Page generated in 0.09392 seconds (76.80% PHP - 23.20% MySQL) with 10 queries
